    Missing Sound, using GPi Case 2
    gpi case 2no sound
    6 Posts 2 Posters 1.1k Views
      Rage
      Hi I hope someone here smarter than me can help me figuring this out
      Level
      Pie and Linux noob
      Hardware
      GPi Case 2
      Raspberry Pi Compute M4 (CM4108000)
      Software
      RetroPie 4.8
      GPiCase2-Script
      Config
      Pastebin
      What I have done
      (removed point 3 and 4 as I tried w/o doing them and it had no effect)
      1. New Image created using Raspberry PI Imager
      2. Added the GPiCase2-Script (to be able to see the screen)
        3. Added a wpa_supplicant.conf to set up the wifi
        4. Added a ssh empty file to activate ssh connection
      3. Inserted the MicroSD into the GPi Case 2 and bootet it up
      It boots up fine but there is no sound, if I go into the sound settings it is set like this
      If i try and increase the system volume and select close or back it is reset back to 0
      Yet increasing the volume does not give any sound
      If I go into Retropie configuration and into Audio I get this
      And the this when the menu loads
      I know there is working sound on the print and in the case, because if I install recalbox then I have sound.
      I found a few other posts talking about this, suggesting redoing image and updating from inside retropie
      neither solved my problem.
      Another suggestion for changing a config file, also did not work.
      sudo nano /usr/share/alsa/alsa.conf
      defaults.ctl.card 0
      defaults.pcm.card 0
      to
      defaults.ctl.card 1
      defaults.pcm.card 1
        Since you disabled the on-board audio (analog) and there's no HDMI connected, it seems the system has no audio outputs defined - hence the errors you get.
        See https://retropie.org.uk/forum/topic/31555/no-sound-retroflag-gpi-case-with-pi-zero-w-2-solved/28?page=2 for a solution - you need an additional configuration line added to config.txt in order to have an audio card show up.
          Rage @mitu
          Thanks for the suggestion.
          From what I could read they said to add this line, to the config
          dtoverlay=audremap,pins_18_19,enable_jack=on
          It had no effect, I tried both the normal speakers and plugged in a mini Jack to check earplug sound.
            mitu Global Moderator @Rage
            @Rage Can you remove the modifications you've done to alsa.conf (from your previous post) and then run speaker-test to see if the test sounds are working ?
              Rage @mitu
              I returned the settings to its original
              when I did the speaker-test i got the following resault
              I tried using the command
              cat /proc/asound/modules
              it only gave me this
                Rage @Rage
                Okay Thanks to mitu because I got to digging into the speaker-test function and because I only had the one snd_usb_audio
                I found out that in the lcd config that comes with the GPi Case 2 patch they have the following in the config
                dtparam=audio=off
                so changing that to on enabled snd_bcm2835 at index 0 then I just followed the Alternate USB Audio Method from RetroPie Docs and changed the snd_usb_audio from index 1 to 0 and rebooted and now I have sound.
                I do not know if this is 100% correct or a buggy workaround as I am all new to Linux. But thanks a bunch for the help :)
