    Need help with booting Pi 4 into emulationstation again. #EmulationStation #Config #SD-CARD
    emulationstationconfigsd-cardhelp
    8 Posts 4 Posters 545 Views
    • 1
      13ooty
      A config.txt file I've used in the past that worked perfectly is now not working at all.
      The most annoying part is that my Pi 4 was booting just fine but then I went to change some display settings to remove the black borders and now my Pi 4 won't boot into emulation station at all. It just ends up on a "no signal" screen after the boot up terminal.
      I've had troubles with my Pi in the past and I've been able to solve the solution by looking up my problem online but I feel like I've hit a dead end here.
      Any help would be much appreciated.
      This is the config.txt I've used.
      overscan_left=10
      overscan_right=-18
      overscan_top=-14
      overscan_bottom=-7
      hdmi_ignore_edid=0xa5000080
      hdmi_force_hotplug=1
      hdmi_group=1
      hdmi_mode=20
      hdmi_drive=2
      config_hdmi_boost=7
      dtparam=audio=on
      dtoverlay=vc4-fkms-v3d
      max_framebuffers=2
      gpu_mem=320
        sleve_mcdichael @13ooty
        @13ooty said in Need help with booting Pi 4 into emulationstation again. #EmulationStation #Config #SD-CARD:
        gpu_mem=320
        This should probably be left on default but in any case the maximum value is 256.
        https://retropie.org.uk/docs/Pi4/#memory-split
        https://retropie.org.uk/docs/Memory-Split/#raspberry-pi-4
        https://www.raspberrypi.com/documentation/computers/config_txt.html#gpu_mem
        I don't know if that would prevent boot though, or just fallback to a supported value such as the default 76 or maximum 256.
        Besides that I'm not sure. I suppose all the hdmi_ settings are necessary because you use a non-standard display/monitor that does not work without them?
        • AshpoolA
          Ashpool
          To add upon @sleve_mcdichael:
          1st.: Please provide some more Info (as mentioned here).
          Then how (th) did you came up with that config.txt? As you mentioned, you only wanted to get rid of the black borders and for that AFAIK the only option you most propably need is disable-overscan, if that is expanding the screen beyond its borders or is still coming with black-border(s) the overscan offsets are the only parameter that (again IIRC) are needed - the no signal most propably is just due to the fact that your display ain't supporting the output your raspi is sending to it due to that config.txt (hdmi_mode 20, or even hdmi_group 1 not supported? Some of the other options adding up to it? As said, too less information offered on your behalf).
          Edit: By the way... hdmi_boost is ignored on the Pi4. It is never a good idea to blindly copy&paste without rtfm'ng the basics.
          1 1 Reply Last reply Reply Quote 0
          • windgW
            windg
            Replace the current config.txt with a fresh one and try again:
            # http://rpf.io/configtxt
            #hdmi_safe=1
            #disable_overscan=1
            #overscan_left=16
            #overscan_right=16
            #overscan_top=16
            #overscan_bottom=16
            # overscan.
            #framebuffer_width=1280
            #framebuffer_height=720
            #hdmi_force_hotplug=1
            #hdmi_group=1
            #hdmi_mode=1
            #hdmi_drive=2
            # no display
            #config_hdmi_boost=4
            # uncomment for composite PAL
            #sdtv_mode=2
            #arm_freq=800
            #dtparam=i2c_arm=on
            #dtparam=i2s=on
            #dtparam=spi=on
            # Uncomment this to enable infrared communication.
            dtparam=audio=on
            [pi4]
            # Enable DRM VC4 V3D driver on top of the dispmanx display stack
            max_framebuffers=2
            [all]
            #dtoverlay=vc4-fkms-v3d
            overscan_scale=1
            • 1
              13ooty
              Thanks for the suggestions you three. I appreciate the help.
              I managed to solve my problem by writing Retropie on my Pi 4 SD card again. I then plugged my Pi 4 back into the TV that wasn't working after enabling the settings I'll mention below, It still came up with no signal after boot up so I used another TV around the house and after my Pi 4 did the first boot up in the terminal and loaded into emulation station on the old TV, I plugged my Pi 4 back into the new TV and it works like nothing happened? If anyone knows how the hell that worked please let me know.
              It has black borders and I'm going to attempt to fix that, lets hope I don't break anything again xD
              • 1
                13ooty @13ooty
                @13ooty
                The config.txt I used.
                #hdmi_safe=1
                #disable_overscan=1
                #overscan_left=16
                #overscan_right=16
                #overscan_top=16
                #overscan_bottom=16
                hdmi_group=1
                hdmi_mode=16
                hdmi_drive=2
                #sdtv_mode=2
                #arm_freq=800
                #dtparam=i2c_arm=on
                #dtparam=i2s=on
                #dtparam=spi=on
                dtparam=audio=on
                [pi4]
                max_framebuffers=2
                [all]
                overscan_scale=1
                • 1
                  13ooty @Ashpool
                  @Ashpool said in Need help with booting Pi 4 into emulationstation again. #EmulationStation #Config #SD-CARD:
                  I'm sorry, I was very tired and frustrated at the time.
                  I used hdmi_boost to allow my TV to show display at one point and it worked I'm pretty sure. I don't need it now for some unknown reason.
                  • 1
                    13ooty @13ooty
                    @13ooty
                    I'm also new to posting on forums so I'm sorry If my writing and information is sloppy xD
