    Update Failed {SOLVED}
    update failed4.8.4
    8 Posts 3 Posters 1.1k Views
    • AddisonA
      Addison
      Raspberry Pi 4 version 4.8.4.
      cd RetroPie-Setup
      git reset --hard
      HEAD is now at 5fceb82e Merge pull request #3734 from cmitu/scraper-fix-dep2
      sudo ~/RetroPie-Setup/retropie_setup.sh
      I goofed around some with adding new repos though I don't think they ever took for some reason.
      I'm sure I messed up something bigly on this.
      Any help? :)
      • AddisonA
        Addison
        Thought I had a fix with a reboot, but that was for a different Pi 4 I already upgraded.
        I have two of them here at home.
        Still hoping for a solution if anyone has an idea for me to try.
        • AddisonA
          Addison
          I was able to update all main and optional packages.
          Only thing is that it continues to be stuck on version 4.8.4.
          Probably doesn't matter much, but it would be nice to have that updated as well.
            sleve_mcdichael @Addison
            @Addison it looks like you did RP-Extra's "update from the old ZeroJay's repo", but you did it from inside RP-Setup instead RP-Extra. Can you do a:
            git remote -v
            ...from inside the Setup (not Extra) directory? If as I suspect it says https://github.com/Exarkuniv/RetroPie-Extra, you should be able to fix it with:
            git remote set-url origin https://github.com/RetroPie/RetroPie-Setup
            AddisonA 1 Reply Last reply Reply Quote 2
            • AddisonA
              Addison @sleve_mcdichael
              @sleve_mcdichael
              pi@retropie:~ $ git remote -v
              fatal: not a git repository (or any of the parent directories): .git
              pi@retropie:~ $ cd RetroPie-Setup
              pi@retropie:~/RetroPie-Setup $ git remote -v
              origin  https://github.com/Exarkuniv/RetroPie-Extra (fetch)
              origin  https://github.com/Exarkuniv/RetroPie-Extra (push)
              • git remote set-url origin https://github.com/RetroPie/RetroPie-Setup
              • sudo ~/RetroPie-Setup/retropie_setup.sh
              After this I was able to upgrade to version 4.8.5.
              Feels good to have the Pi fully current once again.
              Thanks!
                You should probably re-clone the Setup folder from scratch and re-add the extra repository in the ext folder, to prevent any future issues.
                AddisonA 1 Reply Last reply Reply Quote 1
                • AddisonA
                  Addison @mitu
                  I would need something to copy and paste to the command line for that.
                  I have no idea what I previously did wrong before nor how it was nicely resolved.
                  All I can do is try and follow directions from others here.
                    mitu Global Moderator @Addison
                    @Addison said in Update Failed {SOLVED}:
                    Move the existing setup folder out of the way, then clone the latest setup version
                    cd
                    mv RetroPie-Setup RetroPie-Setup.old
                    git clone --depth=1 https://github.com/RetroPie/RetroPie-Setup.git
                    You can then follow the installation instructions for @ExarKunIv's extra repository.
                    • S sleve_mcdichael referenced this topic on
