    RPI 4 Elecrow 5 inch screen error (help)
    elecrow5 inch screentouchscreen
    12 Posts 2 Posters 1.0k Views
    • F
      Fingerprint
      I'm using a Raspberry Pi 4B,
      With an Elecrow 5 inch touchscreen display.
      After modifying /boot/config.txt with the elecrow code to make the screen fit 800x480.
      upon emulationstation boot I get the error
      "*failed to add service - already in use?"
        The Elecrow 'code' (configuration mostly) has disabled the KMS/DRM driver, which is needed on the Pi4.
        Looking at their Amazon page, they state:
        • When intended for Raspberry Pi 4, for the system after 2021-10-30, for example on Bullseye, please modify "dtoverlay = vc4-kms-v3d" to "dtoverlay = vc4-fkms-v3d" in the config file, otherwise it may fail to start. But on Buster, please comment out "dtoverlay = vc4-fkms-V3D" by adding #.
        which clearly disables the 3d KMS overlay needed for the GPU to function. Re-enable the overlay by removing the # before dtoverlay = vc4-fkms-v3d and see if EmulationStation starts up correctly.
        • F
          Fingerprint
          Nope, that still didnt work. I'm getting the same error "*failed to add service - already in use?"
          Here's the configuration settings in config.txt
          # http://rpf.io/configtxt
          #hdmi_safe=1
          #disable_overscan=1
          #overscan_left=16
          #overscan_right=16
          #overscan_top=16
          #overscan_bottom=16
          # overscan.
          #framebuffer_width=1280
          #framebuffer_height=720
          #hdmi_force_hotplug=1
          #hdmi_group=1
          #hdmi_mode=1
          #hdmi_drive=2
          # no display
          #config_hdmi_boost=4
          # uncomment for composite PAL
          #sdtv_mode=2
          #arm_freq=800
          #dtparam=i2c_arm=on
          #dtparam=i2s=on
          #dtparam=spi=on
          # Uncomment this to enable infrared communication.
          dtparam=audio=on
          [pi4]
          # Enable DRM VC4 V3D driver on top of the dispmanx display stack
          dtoverlay=vc4-fkms-v3d
          max_framebuffers=2
          [all]
          gpu_mem_256=128
          gpu_mem_512=256
          gpu_mem_1024=256
          overscan_scale=1
          # --- added by elecrow-pitft-setup ---
          max_usb_current=1
          hdmi_drive=1
          hdmi_group=2
          hdmi_mode=1
          hdmi_mode=87
          hdmi_cvt 800 480 60 6 0 0 0
          dtoverlay=ads7846,cs=1,penirq=25,penirq_pull=2,-
          speed=50000,keep_vref_on=0,swapxy=0,pmax=255,xohms=150,xmin=200,xmax=3900,
          ymin=200,ymax=3900
          display_rotate=0
          # --- end elecrow-pitft-setup ---
            Then start with the default RetroPie Pi4 image and add again the lines neded by the display, omitting the advice from their document about the dtoverlay = vc4-fkms-v3d.
            • F
              Fingerprint @mitu
              Uh Nope that didnt work.
              In fact a rewrote the image after properly erasing everything, and launching it for the first time still showed that error.
              i didnt edit anything at all.
              It didnt do that before.
              What can i do now?
                Can you post the current config.txt ? The previous one had some obvious errors (hdmi_cvt is a command, the dtoverlay=ads784... should be just one line and not several). If it's the same as before, there's no need to post again.
                • F
                  Fingerprint @mitu
                  #hdmi_safe=1
                  #disable_overscan=1
                  #overscan_left=16
                  #overscan_right=16
                  #overscan_top=16
                  #overscan_bottom=16
                  # overscan.
                  hdmi_group=1
                  hdmi_mode=1
                  #hdmi_drive=2
                  # no display
                  #sdtv_mode=2
                  #arm_freq=800
                  #dtparam=i2c_arm=on
                  #dtparam=i2s=on
                  #dtparam=spi=on
                  dtparam=audio=on
                  [pi4]
                  max_framebuffers=2
                  [all]
                  #dtoverlay=vc4-fkms-v3d
                  #gpu_mem_256=128
                  #gpu_mem_512=256
                  #gpu_mem_1024=256
                  overscan_scale=1
                  gpu_mem=128
                  it was working before. I dont know why its having an issue now
                  could it be something with the SD card causing an error?
                    mitu Global Moderator @Fingerprint
                    @Fingerprint said in RPI 4 Elecrow 5 inch screen error (help):
                    I doubt it. The resolution you added is not correct. hdmi_group=1 and hdmi_mode=1 is CEA (TV) at 640x480.
                    You'll need a custom HDMI mode, since the resolution is non standard: Try something like:
                    hdmi_group=2
                    hdmi_mode=87
                    hdmi_ignore_edid=0xa5000080
                    hdmi_cvt=800 480 60 6 0 0 0
                    • F
                      Fingerprint @mitu
                      Nope. Still didnt work. The resolution does display correctly, but it still gives me the error. this is frustrating.
                      Here's the current config file
                      #hdmi_safe=1
                      #disable_overscan=1
                      # overscan.
                      #hdmi_group=1
                      #hdmi_mode=1
                      #hdmi_drive=2
                      # no display
                      #sdtv_mode=2
                      #arm_freq=800
                      #dtparam=i2c_arm=on
                      #dtparam=i2s=on
                      #dtparam=spi=on
                      dtparam=audio=on
                      [pi4]
                      max_framebuffers=2
                      [all]
                      #gpu_mem_256=128
                      #gpu_mem_512=256
                      #gpu_mem_1024=256
                      overscan_scale=1
                      gpu_mem=128
                      # custom hdmi mode
                      hdmi_group=2
                      hdmi_mode=87
                      # custom hdmi mode end
                      #hdmi_safe=1
                      #disable_overscan=1
                      #overscan_left=16
                      #overscan_right=16
                      #overscan_top=16
                      #overscan_bottom=16
                      # overscan.
                      #hdmi_group=1
                      #hdmi_mode=1
                      #hdmi_drive=2
                      # no display
                      #sdtv_mode=2
                      #arm_freq=800
                      #dtparam=i2c_arm=on
                      #dtparam=i2s=on
                      #dtparam=spi=on
                      dtparam=audio=on
                      [pi4]
                      max_framebuffers=2
                      [all]
                      #gpu_mem_256=128
                      #gpu_mem_512=256
                      #gpu_mem_1024=256
                      overscan_scale=1
                      gpu_mem=128
                      # custom hdmi mode
                      hdmi_group=2
                      hdmi_mode=87
                        Are you sure you're using the Pi4 image ? The error message
                        it's displayed by the old RPI GPU drivers, which are used by the Pi3 and below, but are not supported or used by the Pi4.
                        • F
                          Fingerprint @mitu
                          I mean when I downloaded the image from this site it said the file was Retropie 4.8
                          I'll redownload the image again.
                          • F
                            Fingerprint @Fingerprint
                            @Fingerprint
                            Downloading a new image worked! for now.
                            Everything seems to be working, i'll refer back to this forum if i need anymore help. Thanks.
