    Bluetooth keyboard lockup problem
    bluetoothkeyboardcrash
    5 Posts 2 Posters 742 Views
      seroster
      I have a relatively new Raspberry Pi 4 setup with Retropie 4.8.5. I was on 4.8 when I discovered this problem, then updated and tried again, but the behavior is the game: the bluetooth utility can see my new Logitech K380 keyboard, but when I try to connect, the "Please choose a security mode" menu appears and the device/software locks up when I make a choice.
      I've looked through similar cases on the forum but don't see any posts about bluetooth keyboard issues except where "it suddenly started to work" - i.e. I didn't glean a solution from previous threads.
      I do have one other Bluetooth device connected - an 8BitDo controller, which is working correctly.
      I read a post from a while ago about reverting to 4.6 and am wondering if that is what I would have to do? Or trying what is described here? https://core-electronics.com.au/guides/workaround-for-the-retropie-bluetooth-security-bug/
      Sorry if I'm being stupid,
      Chris
        Try the procedure from https://unix.stackexchange.com/questions/590221/pairing-logitech-k380-in-ubuntu-20-04, using the bluetoothctl command line utility. Seems the kekyboard may need a pairing code to complete the pairing with the Pi.
          seroster
          Thanks, I got partway through the bluetoothctl process but it gave output not quite like was shown in that example.
          I can get to the terminal (hadn't done this before) and run bluetoothctl
          I can get the MAC address of the keyboard
          I can issue the trust command and that succeeds.
          However, when I try to pair, I see:
          [bluetooth]# pair <macaddress>
          [CMG] Device <macaddress> Connected: yes
          [agent] Passkey: 056660
          [Keyboard K380]# _
          The underscore is the cursor, if that's not clear. And at that point I am not sure what I am supposed to do, and after a little bit pairing times out/fails.
          Any ideas?
            mitu Global Moderator @seroster
            @seroster said in Bluetooth keyboard lockup problem:
            From the link I mentioned, I understand you type the passkey on the keyboard to complete the pairing ?
              seroster @mitu
              @mitu Ahhh on the keyboard to be PAIRED? No, I did not understand. Thanks, I'll try that.
              edit: of course, it now works. I can't quite believe I didn't understand that part of the instructions haha
