    Error with Mono Audio Script for GamePi43
    retropieaudiomono
    1 Posts 1 Posters 351 Views
    • DolphinCubeD
      DolphinCube
      Hello there. I am having a bit of an issue with my Pi
      So a long time ago. I have created this post for help because my pi case only supported mono audio. and I've been given instructions in it on how to change the HDMI audio to do so. It worked for a while but now I had to get a new sd card and flash it to work with the pi. And it no longer works. Is there any other script or some kind of fix that can help me with this issue?
      The case does NOT use the built in audio jack on the Pi. It is only HDMI with a seperate 3.5mm headphone jack thats stereo attached to the case itself. I dont really mind playing my games in mono if I'm using headphones. But I really need a fix for this
