    eDuke32 doesn't load title screen for Duke: Caribbean Vacation - Life's a Beach
    duke 3d-atomicvacationaddonseduke32
    12 Posts 5 Posters 1.8k Views
    • Striderx99S
      Striderx99
      Hello everyone. I'm using a Pi 4B with 4 GB of ram (64 bit) and the OS is Linux 5.10.17-v8+ aarch64 Raspbian. Recently, I've tried launching eDuke on the RetroPie. I was able to get the addons (Nuclear Winter and Duke it Out In DC) working, but I'm still having difficulty with Caribbean Vacation. I was able to find a copy of Duke Nukem: Megaton Edition and went to the addons folder (inside the Gameroot folder) to grab the files. I went to the duke3d folder in RetroPie and added the dc, nw, and vacation folders to the addon folder. There was also a classic folder (also inside the Gameroot folder) with the Duke Nukem: Atomic Edition files. I added a few of those inside the duke3d folder on the RetroPie (duke3d.grp, DUKE3D.CFG, DUKE.RTS, USER.CON, and GAME.CON).
      Within the vacation folder (inside the addons folder) I added DUKE.RTS, DUKE3D.CFG, duke3d.grp, GAME.CON, VACA1.MAP, VACA2.MAP, VACA3.MAP, VACA4.MAP, VACA5.MAP, VACA6.MAP, VACA7.MAP, VACADM1.MAP, VACADM2.MAP, VACADM3.MAP, VACADM4.MAP, VACAPP.SSI, VACASL.MAP, VACATION.CON, VACDEFS.CON, VACUSER.CON, and vacation.grp. When I click on the Duke - Caribbean Vacation - Life's a Beach.sh, the app loads the title screen for Duke Nukem 3D: Atomic Edition game instead of the one for Caribbean Vacation. I'm wondering if I'm missing any other files or may have placed one or more of them in the wrong folders. Does anyone have an idea of what might be wrong? Please let me know. Thanks for your input. :-).
      RapidEdwin08R 1 Reply Last reply Reply Quote 0
      • RapidEdwin08R
        RapidEdwin08 @Striderx99
        @Striderx99 Here's what works for me, only file needed in there is vaction.grp.
        ./duke3d/DUKE3D.GRP    md5: 22b6938fe767e5cc57d1fe13080cd522
        ./duke3d/DUKE.RTS      md5: 9d29f9673bbdb56068acf7645c13749c
        ./duke3d/addons/vacation/vacation.grp    md5: 1c105ced73b776c172593764e9d0d93e
        Duke3D Caribbean .sh:
        _PORT_ "duke3d" "-j/home/pi/RetroPie/roms/ports/duke3d/ -j/home/pi/RetroPie/roms/ports/duke3d/addons/vacation -addon 3"
        Raspberry Pi B, Pi B+, Pi2 B, Pi3 B, Pi3 B+, Pi Zero W, Pi4 (4GB/8GB), Pi5 (8GB/16GB), Pi Zero 2 W, GPi V1, minisforum GK50 / RetroPie 4.8.x
        Striderx99S S 2 Replies Last reply Reply Quote 0
        • Striderx99S
          Striderx99 @RapidEdwin08
          @RapidEdwin08 The vacation.grp in my folder has that md5 checksum. The other two (DUKE3D.GRP and DUKE.RTS) also have the matching md5 checksums you have listed. At least I know that I have the correct files for the main game and the Vacation DLC. I think I might be missing one or more files that is/are necessary to make the title screen with Duke standing over the pigcop's head (buried in the sand) with two women standing nearby in the water. Since I'm using the Megaton Edition files, it is slightly different. I'm pretty sure there's something missing because when you load Duke it Out in DC, there is an emblem added to the far left along with the normal Atomic Edition title on the screen. With Nuclear Winter, that part of the title also gets added to the Duke Nukem 3D: Atomic Edition portion. All of these appear when you run the games as originally intended on a PC.
          I might be wrong in saying all of this, as this is eDuke32 (Raspberry Pi) that loads all the necessary files. It may actually use the regular Atomic Edition title. If anyone has an idea, please let me know.
          ectoE 1 Reply Last reply Reply Quote 0
          • ectoE
            ecto @Striderx99
            @Striderx99 I checked my installation and it shows the same behavior as yours. I'm using the atomic edition as a base.
            What also puzzles me is the episode selection: in vacation and dc, the new episode replaces ep 3 of 4, while the nw episode replaces ep 2 (and there is only LA meltdown as ep 1 an no others)
            ...strange.
            • Striderx99S
              Striderx99
              I'd like to try another emulator that will load these files to see the result. Maybe rednukem would work? I would have to check the RetroPie documentation to see if there might be others as well.
              • ExarKunIvE
                ExarKunIv @Striderx99
                @Striderx99 no rednukem will not work. That is built only to run redneck rampage. That's it
                There is no other engine that runs duke3d that works in the pi that I know of.
                  sleve_mcdichael @RapidEdwin08
                  @RapidEdwin08 do you just mean the game itself works, or do you really mean the title screen?
                  I have a different GRP file with a different checksum (from installation CD, not Steam download) and I get the same result as @ecto and @Striderx99 does, where the game does play, it's just the title/splash screen is wrong, it still just shows the Atomic Edition splash instead the Vacation one. DC shows an altered splash screen with the DC badge in one corner, and NW shows a whole animated cutscene at the start, but Vacation just shows the regular AE splash.
                  • ExarKunIvE
                    ExarKunIv @sleve_mcdichael
                    @sleve_mcdichael said in eDuke32 doesn't load title screen for Duke: Caribbean Vacation - Life's a Beach:
                    Maybe that's how it should be?
                    I never tried it on a PC so I don't know if it changes or what
                    • Striderx99S
                      Striderx99
                      When you load the Vacation DLC (from the Megaton Edition), it shows the title screen that I mentioned on the PC. There's also a different title screen for Duke it Out in DC (just including a banner on the upper left with the title) and the Atomic Edition logo on the bottom. Nuclear Winter just has that title bundled together with the Atomic Edition logo. I can also confirm with what @ecto said about the episodes appearing on each of the menus.
                      When it's all said and done, the games are playable, but it appears that eDuke32 is missing that title screen. Menu items also appear differently. I may try to throw in Penthouse Paradise to see if I can get it working too. I don't know if there are any multiplayer sections that work.
                      • ectoE
                        ecto @Striderx99
                        @Striderx99 oooh! What is Penthouse Paradise? I. Need. More. Duke! ;)
                        Striderx99S 1 Reply Last reply Reply Quote 0
                        • Striderx99S
                          Striderx99 @ecto
                          @ecto It's another DLC that sounds exactly like what it is. ;-P. I don't think you will find the CD version for purchase anymore, however. Google it and explore, you'll eventually find it.
                          • ExarKunIvE
                            @Striderx99 If you tried the file from both the atomic and megaton edition and the same outcome. Then it's eduke.
                            You can go on eduke GitHub and see what they say. Can't say they will do anything or not
