    Setting Up Light Gun For Raspberry Pi
    lightgunretropielightgun roms
    9 Posts 3 Posters 2.3k Views
      arcadelover15
      Hi Guys,
      I recently bought a cabinet with a Pandors box that has light gun games. I was wondering if anyone has a link to a good tutorial for setting up Light gun ROMS on a rasberry Pi Model B 4G?
      Any help or guidance in the right direction is appreciated.
      ByteThisB 1 Reply Last reply Reply Quote 0
      • ByteThisB
        ByteThis @arcadelover15
        [deleted]
          arcadelover15 @ByteThis
          @ByteThis I will be wanting to run this on Retropie.
          • mituM mitu moved this topic from General Discussion and Gaming on
          • ByteThisB
            [deleted]
            A Thorr69T 2 Replies Last reply Reply Quote 0
              @ByteThis Hi Mate, the cabinetry came with the Pandoras box. I have experience refitting these with Rasberry pis and running retropie, however I do not have any experience with Light guns, hence the question.
              • Thorr69T
                Thorr69 @ByteThis
                @ByteThis said in Setting Up Light Gun For Raspberry Pi:
                @arcadelover15 Confusing as your asking for help for Pandora's box..but Retropie doesn't run on that unless your going to put a Pi in it..but you will still have to reconfigure all for a retropie build.
                Pandora's Box hardware can be used as a controller (xbox or playstation compatible). I have a PBox 5 that use as my arcade control setup on my Pi3b. I removed the thumb drive inside so that the PBox doesn't run anything internally when I turn it on. The controls are a bit sponge-y but it's a great out-of-the-box solution for an arcade setup overall. All it took was one tweak in setup to make the PBox be recognized as 2 controllers.
                RPi 3b
                Official PSU
                Official RetroPie image
                Pandora's Box 5 controller
                ByteThisB A 2 Replies Last reply Reply Quote 0
                • ByteThisB
                  ByteThis @Thorr69
                  This post is deleted!
                    arcadelover15 @Thorr69
                    @Thorr69 Hey mate, thank you so much for this idea. Would it be to much to ask for a way to send you a private message to go through how you set this up?
                    • Thorr69T
                      Thorr69 @arcadelover15
                      @arcadelover15 There wasn't a whole lot to it. The box itself is designed to be used as a controller if you want, so it was just a matter of hooking up BOTH usb cables to the Pi. (Each cable is one side of the control panel.) I think the setup tweak I used initially might be no longer needed in current versions of RetroPi.
                      Here is a thread I gave my info in:
                      https://retropie.org.uk/forum/topic/30623/pandora-box-used-as-game-pad
                      RPi 3b
                      Official PSU
