    Retropie on Khadas Edge 2 running Armbian can't get sound in games to work over HDMI
    edge2soundhdmi
    4 Posts 2 Posters 524 Views
      thisisnotdave
      I've gotten just about everything to work well and sound works in emulationstation itself but not in any emulator.
      Here is the output of aplay -L and -l
      khadas-edge2:~:% aplay -L
      null
          Discard all samples (playback) or generate zero samples (capture)
      samplerate
          Rate Converter Plugin Using Samplerate Library
      speexrate
          Rate Converter Plugin Using Speex Resampler
      jack
          JACK Audio Connection Kit
      oss
          Open Sound System
      pulse
          PulseAudio Sound Server
      upmix
          Plugin for channel upmix (4,6,8)
      vdownmix
          Plugin for channel downmix (stereo) with a simple spacialization
      hw:CARD=rockchipdp0,DEV=0
          rockchip,dp0, rockchip,dp0 spdif-hifi-0
          Direct hardware device without any conversions
      plughw:CARD=rockchipdp0,DEV=0
          Hardware device with all software conversions
      sysdefault:CARD=rockchipdp0
          Default Audio Device
      dmix:CARD=rockchipdp0,DEV=0
          Direct sample mixing device
      usbstream:CARD=rockchipdp0
          rockchip,dp0
          USB Stream Output
      hw:CARD=rockchiphdmi0,DEV=0
          rockchip,hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0
      plughw:CARD=rockchiphdmi0,DEV=0
      sysdefault:CARD=rockchiphdmi0
      dmix:CARD=rockchiphdmi0,DEV=0
      usbstream:CARD=rockchiphdmi0
          rockchip,hdmi0
          USB Stream Output
      usbstream:CARD=rockchipsoundmi
          rockchip,sound-micarray
          USB Stream Output
      hw:CARD=rockchipes8316c,DEV=0
          rockchip,es8316-codec, fe470000.i2s-ES8316 HiFi ES8316 HiFi-0
      plughw:CARD=rockchipes8316c,DEV=0
      sysdefault:CARD=rockchipes8316c
      dmix:CARD=rockchipes8316c,DEV=0
      usbstream:CARD=rockchipes8316c
          USB Stream Output
      khadas-edge2:~:% aplay -l
      card 0: rockchipdp0 [rockchip,dp0], device 0: rockchip,dp0 spdif-hifi-0 [rockchip,dp0 spdif-hifi-0]
        Subdevices: 1/1
        Subdevice #0: subdevice #0
      card 1: rockchiphdmi0 [rockchip,hdmi0], device 0: fddf0000.i2s-i2s-hifi i2s-hifi-0 [fddf0000.i2s-i2s-hifi i2s-hifi-0]
        Subdevices: 1/1
      card 3: rockchipes8316c [rockchip,es8316-codec], device 0: fe470000.i2s-ES8316 HiFi ES8316 HiFi-0 [fe470000.i2s-ES8316 HiFi ES8316 HiFi-0]
        Subdevices: 1/1
      khadas-edge2:~:% amixer scontrols -D sysdefault:CARD=rockchiphdmi0
      Simple mixer control 'I2STDM Digital Loopback Mode',0
      Simple mixer control 'ELD Bypass',0
      I've tried several options in my es_settings.cfg but no luck so far. Does anyone have any ideas of what else I can try?
      <string name="AudioCard" value="sysdefault:CARD=rockchiphdmi0" />
      <string name="AudioDevice" value="ELD Bypass" />
      <string name="CollectionSystemsAuto" value="" />
      <string name="CollectionSystemsCustom" value="" />
      <string name="GamelistViewStyle" value="automatic" />
      <string name="LeadingArticles" value="a,an,the" />
      <string name="OMXAudioDev" value="Both" />
      • mituM mitu moved this topic from General Discussion and Gaming on
        The Audio settings in EmulationStation don't apply globally to any application. What you need is to set the right ALSA audio card as 'default' so any program using ALSAlib will pick it up automatically.
        Since this is a relativelly powerful device, why don't you install Pipewire & Wireplumbler and let them route the audio automatically ?
          thisisnotdave @mitu
          Thanks, I didn't know that was an option. Is there any documentation on retropie and pipewire/wireplumber?
          EDIT
          Got pipewire and wireplumber working, i have sound now in all my cores. Thanks!
          Is there a way to supress the VolumeControl::getVolume() - Failed to get volume range! error I see every time I launch a game?
            mitu Global Moderator @thisisnotdave
            @thisisnotdave said in Retropie on Khadas Edge 2 running Armbian can't get sound in games to work over HDMI:
            Change the Audio Device setting in EmulationStation's Audio menu to Master or PCM and this should get rid of the warning.
