    Sounds get jittery/ start dropping out after using system for an hour or so
    musibackgroundretropie config
    6 Posts 2 Posters 1.1k Views
    • W
      wtstreetglow1
      Hello,
      Does anyone have any ideas of what could be causing the subject or what I should look into.
      This issue only seems to happen after the pi4 (Retropie 4.8) has been used for an extended amount of time (>1 hour). It began being noticed very prevalently after getting the system to run some background music on the system/ game selection screens.
      Thank you all for any guidance you can provide.
        Please provide some info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        If you have some 3rd party background music scripts, try disabling them first and see if that changes anything. How are you using the system in that time ? Are you playing games or just leave the front-end (EmulationStation) with the bg music running ?
        • W
          wtstreetglow1 @mitu
          @mitu Thank you again for your response here @mitu
          See below for system info:
          Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..): pi 4b 64 bit
          Power Supply used: (If using a Pi): Canakit 3.5 Amp
          RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.8
          USB Devices connected: rii mini wireless keyboard, wired mouse, wired keyboard
          Controller used: none yet (just setting up currently)
          I have uninstalled all 3rd party music scripts for now.
          This happens pretty much anytime the system is left idle for longer periods of time.
          Leaving the front-end with the bg music running is the response to the last question.
          Thank you again @mitu
            mitu Global Moderator @wtstreetglow1
            @wtstreetglow1 said in Sounds get jittery/ start dropping out after using system for an hour or so:
            There's no bg music in EmulationStation by default - you still have some music add-on installed. If you can open a SSH session when the slowdown occurs, you can use the top command to look at what processes are running and which one of them gets the most resources (CPU/Memory).
            W 1 Reply Last reply Reply Quote 1
            • W
              wtstreetglow1 @mitu
              @mitu said in Sounds get jittery/ start dropping out after using system for an hour or so:
              Thank you for this idea. I think you've already figured out the problem.
              The 3rd party script that was being used is using a music folder that is in my roms directory.
              My roms directory is a network share. I have a feeling thats just a bad idea in general for stability.
              I will try to find a 3rd party script that puts the music in a different location and see if this behavior continues with a different script after uninstalling the current one.
              Thank you for helping me get to the bottom of this one!!
              • W
                wtstreetglow1
                For people that end up seeing this in the future. I ended up using the below as my final solution for music- simple, has necessary features- just watch the install video at his website:
                https://retropie.org.uk/forum/topic/25125/how-to-add-background-music-in-just-5-commands/2
