    i found a cause and a fix/bandaid for psx no bios no controller issue
    6 Posts 3 Posters 4.6k Views
      edmaul69
      ok so both problem are created by the /opt/retropie/configs/psx/retroarch.cfg So i learned a while back that if you add the right junk in a retroarch.cfg file you can keep it from being overwritten and this fixes both problems. here is what i have in my /opt/retropie/configs/psx/retroarch.cfg
      input_remapping_directory = "/opt/retropie/configs/all/retroarch-joypads/"
      input_player7_r_x_plus_axis = "+2"
      input_player7_r_x_minus_axis = "-2"
      input_player7_r_y_plus_axis = "+3"
      input_player7_r_y_minus_axis = "-3"
      input_player8_r_x_plus_axis = "+2"
      input_player8_r_x_minus_axis = "-2"
      input_player8_r_y_plus_axis = "+3"
      input_player8_r_y_minus_axis = "-3"
        edmaul69
        so i found that all my configs are getting changed in 4.0.1. however since i have stuff in my other files it is not overwriting them but it is moving the #include line to the bottom of the retroarch.cfg files here is what most of my retroarch.cfg files look like:
        input_player1_joypad_index = "0"
        input_player1_up_axis = "-1"
        input_player1_down_axis = "+1"
        input_player1_left_axis = "-0"
        input_player1_right_axis = "+0"
        input_player2_joypad_index = "1"
        input_player2_up_axis = "-1"
        input_player2_down_axis = "+1"
        input_player2_left_axis = "-0"
        input_player2_right_axis = "+0"
        so i am not sure what changed from 4.0 beta 2 to 4.0.1 that is causing this?
        • FloobF
          Floob
          The #include line is moving to the end to make it clear that these are overrides.
          If you put lines after the #include they will only work if they dont already exist in the global retroarch.cfg file, so its unlikely thats required.
          If you want a global setting it should go in the global file.
            BuZz administrators
            Not sure why you are setting input_remapping_directory in each config either - that is set in the main retroarch.cfg.
            [edit] sorry misread - read input_remapping_directory but brain saw joypad_autoconfig_dir. Not sure the advantage of moving those configs though.
              edmaul69 @Floob
              @Floob i have been using my configs for a long time with stuff underneath the #include.. line. it was not until 4.0.1 i installed yesterday did they start getting rearranged. but at any case i managed to get psx working this way. i found other emulators were overwriting the retroarch.cfg as well. possibly all of them except that i have stuff in my retroarch.cfg files preventing them from being overwritten. but they did get rearranged
                BuZz administrators
                well configs under might work if the entry didn't exist in the global retroarch.cfg, but you could run into trouble. I don't think the order is relevant to the problem - we are debugging in the other thread.
