    Problem with momentary button
    momentary
    2 Posts 2 Posters 648 Views
      blacknell
      I've hooked up a momentary button but the device is not performing as expected.
      When I first apply power, the RPi does not power up. I must press the button to switch on. Later pressing it again shuts it down.
      But after a power cut, the device stays off.
      I can't live with this - if I'm away then the RPi's must boot up after a power cycle.
      I tried using the NC contacts and that works on boot but then - I think - the onboard is deciding its a toggle switch and so pressing it shuts it down and immediately reboots it.
      Can you help?
      I have bought 5 of these boards and 5 switches so I really need a fix
        petrockblog Global Moderator @blacknell
        @blacknell Hi! I have just replied to your email.
        Generally, the default PowerBlock firmware does not return to the previous power state upon power loss. However, I did work on this feature some months ago and I built an updated firmware version for the PowerBlock that contains this feature: Upon switch on, the PowerBlock persists the ON state as target state. When in ON state and a power button switch off event is observed the OFF state is persisted as target state. When a power-reset event occurs the PowerBlock returns to the previously persisted target state.
        If you have a programmer for the ATTiny85 microcontroller on the PowerBlock you could just download this other firmware.
        I am happy to provide this firmware upon request. New batches of the PowerBlock might get this firmware per default, eventually.
