GPI Case 2W Display issue with RetroPie
Help! Just bought a GPI case 2W and running Retropie as per instructions, but the GitHub patch does not make a difference.
Anyone got this working or has a blank retropie GPI Case2W Image I can use for now :) HELP!!!!Got the screen issue. RecalBox works fine but I would like to use RetroPie as it is installed on all my other Pi devices :)
Another topic open recently with same issue but no luck. It looks that they company focus on RecalBox and don't provide newer version of the patch for the RetroPIe.
I recommend you to ask and in the RetroPIe community in Reddit: https://www.reddit.com/r/RetroPie/ and in the retroflag community : https://www.reddit.com/r/retroflag_gpi/ .
Actually I now have it working after finding an image online that was setup ready to go :)
just copying the roms across to test now :)
