    Cocktail cabinet woes RPi 4b 8gb
    mamerpi4retropieverticalcocktail
    5 Posts 4 Posters 659 Views
      krullbeast
      Hello,
      I'm trying to use a 1080p 41 inch tv for a cocktail table set up. I have an ipac2 usb controller 2 player set up. So far I have the screen rotate figured out in the emulationstation config with --screenrotate 1 -- screensize 960 1280. the only thing i didn't rotate was the text because i'm not going to be doing much typing after i have it all set up. My issue is when I try to launch a game in MAME it just boots back to the menu screen. I've tried changing the video outputs when launching and other versions of mame. I have these roms on another cabinet and they work great. I'm confused. When i try to load a core in retroarch all that is there is the virtual retropad. Do i need to install the MAME core in retroarch if it's already showing in the menu? I've read online that there are issues with a vertical pi4b set up, but i see that some folks have them working, so i know that it CAN be done. Could someone please throw this dog a bone? I have never had this much trouble setting up a retropie before. I'm ashamed at how many youtube videos i've watched recently. I've come to my wits end. If there's anything you'd recommend, I will surely try it. Thank you!
      -Lee
      Pi 4b 8gb, official canakit power supply, IPAC2 usb controller, 41 inch tv,
      mituM WeirdHW 2 Replies Last reply Reply Quote 1
        mitu Global Moderator @krullbeast
        @krullbeast said in Cocktail cabinet woes RPi 4b 8gb:
        Arcade roms are tailored to the particular arcade emulator and it's version - see the arcade/MAME emulation doc page. You most likely don't have the correct romset archives for the particular arcade emulator you're using, I don't think it has to do with the orientation of the display.
        • WeirdHW
          WeirdH @krullbeast
          @krullbeast https://retropie.org.uk/Arcade/
          Step 2 is very important here. Console games do not require this, but arcade works differently.
          • Thorr69T
            Thorr69 @WeirdH
            @WeirdH said in Cocktail cabinet woes RPi 4b 8gb:
            Your link goes nowhere.
            RPi 3b
            Official PSU
            Official RetroPie image
            Pandora's Box 5 controller
              mitu Global Moderator @Thorr69
              @Thorr69 said in Cocktail cabinet woes RPi 4b 8gb:
              https://retropie.org.uk/docs/Arcade/
