    Pi 5 - Playstation emulator (lr-pcsx-rearmed) does not load games -Segmentation fault
    pi5lr-pcsx-rearmedstart issues
    7 Posts 3 Posters 2.5k Views
      dk23
      Pi Model or other hardware: Pi 5 8GB / raspi os bookworm lite x64
      Power Supply used: recommended / Pi official
      RetroPie Version Used: Setup-script 4.8.6
Built From: Source / official setup script
      USB Devices connected: Stick - operation system / JSAUX audio card / HDD
      Controller used: 2 x 8bito SN30pro - bluetooth
      Error messages received:
      tail /dev/shm/runcommand.log output:
      Parameters: Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/pcsx_rearmed_libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/myrom.cue" --appendconfig /dev/shm/retroarch.cfg /opt/retropie/supplementary/runcommand/runcommand.sh: line 1319: 1941 Segmentation fault /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/pcsx_rearmed_libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/myrom.cue" --appendconfig /dev/shm/retroarch.cfg
      Verbose log: I do not know which log to provide, probably this:
      strace output
      https://pastebin.com/BxS2bYkn
      Guide used: Playstation guide / ROMs on HDD guide
File: seems to be this combination - the pcsx_rearmed_libretro.so/ part
      Emulator: lr-pcsx-rearmed
      Attachment of config files: standard config
 (as far as I know)
      How to replicate the problem:
      Try to start game via emulation station - boot screen - black screen - returns to game selection in GUI
      The Playstation emulator (lr-pcsx-rearmed) does not load games and causes a segmentation fault.
      Everything else works like a charm on my system. Does anyone have a solution or can give me hints how to debug further? I would appreciate any help!
      Cheers, dk23
        mitu Global Moderator @dk23
        @dk23 said in Pi 5 - Playstation emulator (lr-pcsx-rearmed) does not load games -Segmentation fault:
        The Pi5 is not currently supported, support for it is currently pending.
        • windgW
          windg
          Add to the config txt file this line and try again: kernel=kernel8.img
            dk23 @mitu
            @mitu But the cool thing, I can say is, that it works nearly perfectly fine :-) So keep up your good work, and you could certainly support it!
              dk23 @windg
              @windg Thank you! Works. I am curious. Could you please elaborate a little on the topic? Why does this option help and what does it do?
              Despite of my curiousity we can mark this as solved!
              windgW 1 Reply Last reply Reply Quote 0
              • windgW
                windg @dk23
                @dk23
                About this :
                https://retropie.org.uk/forum/post/292152
                  dk23 @windg
                  @windg Thank you!
