    Doom The Way Pi Did [Doom-Ready Base Images for Raspberry Pi 0-5 + GPi]
    doomdtwpidgzdoompi5retropie
    34 Posts 8 Posters 19.8k Views
      Retrodade @RapidEdwin08
      @RapidEdwin08 nice, thank you same link as before? right
      RapidEdwin08R 1 Reply Last reply Reply Quote 0
      • RapidEdwin08R
        RapidEdwin08 @Retrodade
        @Retrodade yes same links in the OP.
        Raspberry Pi B, Pi B+, Pi2 B, Pi3 B, Pi3 B+, Pi Zero W, Pi4 (4GB/8GB), Pi5 (8GB/16GB), Pi Zero 2 W, GPi V1, minisforum GK50 / RetroPie 4.8.x
        • RapidEdwin08R
          RapidEdwin08
          I was recently informed by the community that WINE is installable on Pi5 Bookworm via pi-apps.
          But I ran into this error with pi-apps trying to install anything on DTWPID3/4/5:
          Unable to open a terminal-emulator
          Error occured when calling terminal-run
          Default x-terminal-emulator.konsole
          Using konsole
          /home/pi/pi-apps/etc/terminal-run: line 95: konsole: command not found
          This Error was due to a combination of the Default Terminal being set as konsole + the fact that I totally forgot to add Trinity PATHs to $PATH.
          Fix for pi-apps if you're running DTWPID3/4/5:
          # Set LXTerminal as the Default x-terminal-emulator
          printf "%s\n" "4" | sudo update-alternatives --config x-terminal-emulator
          # Add Trinity Paths to $PATH for All Users
          echo 'export PATH=$PATH:/opt/trinity/bin:/opt/trinity/games:/opt/trinity/sbin' > ~/01-trinity-path.sh
          chmod 755 ~/01-trinity-path.sh; sudo chown root ~/01-trinity-path.sh
          sudo mv ~/01-trinity-path.sh /etc/profile.d/01-trinity-path.sh
          Once I changed the default terminal to lxterminal, I was able to install WINE/box64 with pi-apps.
          The other commands will add Trinity PATHs for good measure, but it's Not really needed to run pi-apps as long as you set the default terminal to lxterminal.
          These Fixes/Changes will be included in the next Update of DTWPID.
          ...And before anyone asks, No, I do Not anticipate adding WINE to DTWPID.
          But I will most likely update/include a WINE System for Emulationstation, essentially making DTWPID "WINE Ready" to run SH/EXEs once you installed WINE yourself via pi-apps
          phillip_benoitP 1 Reply Last reply Reply Quote 0
          • phillip_benoitP
            phillip_benoit @RapidEdwin08
            @RapidEdwin08 I've had no trouble with Doom on Dos Box
            • RapidEdwin08R
              RapidEdwin08 @phillip_benoit
              @phillip_benoit Sure,
              But with WINE you can play Windows games like Duck Doom Deluxe, and probably miniDoom2.
              • phillip_benoitP
                @RapidEdwin08 Well, you'd have to install Win98 and you certainly wouldn't want to put that on an image you distribute. DOS does have thousands of shareware games, though. I've heard you can even set up IPX over TCP/IP and do network play. A lan party distro might be cool. Everyone bring their Pi, their screen, inputs, and an empty sd card.
                • RapidEdwin08R
                  RapidEdwin08
                  Updated Doom the Way Pi Did IMGs Released 20240620 20240629
                  Changes worth noting:
                  dolphin +Vulkan
                  GZDoom 4.12.2 +Vulkan
                  DSDA-Doom
                  ROTT-Expr
                  pi-apps Installer: RetropieMenu -> Utilities -> GIT-pi-apps
                  WINE Ready ES System: Install WINE from pi-apps
                  QJoyPad support for Desktop, WINE, DuneLegacy, HexenII, NBlood, PCExhumed, ROTT-Expr
                  Fixed pi-apps DTWPID3/4/5: Default x-terminal-emulator LXTerminal + Trinity Paths
                  Moved Added QJoyPad from roms/wine to RetropieMenu -> Utilities -> QJoyPad
                  Issues worth noting:
                  Mouse Cursor Randomly/Repeatedly will Not appear when Opening QJoyPad from Emulationstation.
                  Better off going to Desktop to modify QJoyPad Mappings or be ready to pkill qjoypad via SSH.
                  Added a Workaround to get the Mouse Cursor to show every time that involves simply starting lxappearance before qjoypad.
                  R 2 Replies Last reply Reply Quote 0
                    @RapidEdwin08 Nice!
                    I have a question the OpenBor game loaded but doesn't seem toload, controller wise I also added another openbor game to see if it was a controller issue, I cant get any to load..ideas?
                    Openbor work on pi5 or no? Thanks
                      @RapidEdwin08 Question,
                      It appears that chromium may be installed? so it seems
                      but im not seeing any.sh or a way to launch it?
                      • RapidEdwin08R
                        @Retrodade OpenBOR seems to work for the most part, but I did have an issue with screen resolution, so I added an emulator entry for OpenBOR to use XINIT to overcome that.
                        Using XINIT for OpenBOR works for games I load, but it also results in a pink screen for the OpenBOR Main Menu, I never pursued this any further since the Games work.
                        If you are having issues with Controller in OpenBOR, the config files live here:
                        /opt/retropie/configs/ports/openbor/Saves/default.cfg
                        /opt/retropie/configs/ports/openbor/Saves/Ultra-Violence.bor.cfg
                        I don't think you can edit those OpenBOR cfg files, but you can delete them or rename them to wipe the controller settings.
                        Regarding Chromium, yes it's installed, along with Firefox and Dillo, and they are all accessible from any of the Desktop Environments.
                        I did not add any Browser sh scripts to Emulationstation and I don't really plan on it moving forward.
                        • RapidEdwin08R
                          RapidEdwin08
                          Updated Doom the Way Pi Did IMGs Released 20240814 (for rPi4/rPi5)
                          Rebuilt using 2024-07-04-raspios-bookworm-arm64.img with Labwc (Lab Wayland Compositor).
                          RetroPie 4.8.8
                          Added lr-flycast-dev
                          Current Systems utilizing +Vulkan on DTWPID4/5:
                          GZDoom
                          Aethersx2
                          *dolphin/lr-dolphin
                          *lr-ppsspp
                          lr-flycast/lr-flycast-dev
                          These latest IMGs seem to be the most stable Bookworm64 Builds I've used so far on rPi4/rPi5.
                          I may try to Update the 0lder rPi3/0 IMGs to Bookworm32 now that Buster is officially out of LTS.
                          But the last time I tried I was still experiencing GPU Reset Issues...
                            michaeldollar
                            This is so badass. Thank you.
                            • RapidEdwin08R
                              RapidEdwin08
                              Updated Doom the Way Pi Did IMGs Released 20250202
                              Updated for compatibility with Pi5 16GB Model
                              Rebuilt using 2024-11-19-raspios-bookworm-arm64.img
                              Updated RetroPie to 4.8.9
                              Updated IMP to 2025.01
                              Added lr-puae2021
                              Added/Updated ppsspp Launcher (now launching with +Vulkan)
                              • RapidEdwin08R
                                RapidEdwin08
                                Updated Doom the Way Pi Did IMGs Released 20250616
                                Updated GZDoom to v4.14.2
                                (+The Latest version of myhouse to match)
                                That's about it, no other Updates or Kernel changes or anything.
                                Honestly I did not want to make any changes at all since this IMG has been Rock Solid for me on x3 Pi5's including 16GB model.
                                But the changelog for GZDoom v4.14.x was HUGE.
