    Help using CD-I
    cd-i
    3 Posts 2 Posters 389 Views
    • E
      escc1986
      Haven’t used my pi 3 in a while
      Just pulled it out
      Want to play CD-I games
      Navigates to my retropie set up
      I have Ir-mess-cdi ( installed -via source)
      When I start a CDI game
      The controls are floating
      And the quality is very slow lots of slow down
      Can anyone hold my hand and walk me step by step how to update my CDI like it was before
      Smooth speed , and the controls were correct
      ( just curious can I get SAME CD-I for retroarch on the pi )
      Hope someone can help me
      Thank you
        We don't include such emulator in RetroPie (Ir-mess-cdi ). If you're using the scripts provided by @folly in https://retropie.org.uk/forum/topic/29682, then please post in that topic.
        • E
          escc1986 @mitu
          Thank you for the recommendation for help
          I appreciate that
