    problems instaling homebridge
    home breweror
    5 Posts 2 Posters 1.2k Views
      compukit
      i have a problem instaling homebridhe when im coming to this pont end get this erro and i dont now how to fix it.
      root@retropie:~# sudo npm install -g --unsafe-perm homebridge hap-nodejs node-gyp
      npm WARN npm npm does not support Node.js v10.24.0
      npm WARN npm You should probably upgrade to a newer version of node as we
      npm WARN npm can't make any promises that npm will work with this version.
      npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
      npm WARN npm You can find the latest version at https://nodejs.org/
      npm ERR! code EUNSUPPORTEDPROTOCOL
      npm ERR! Unsupported URL Type "npm:": npm:string-width@^4.2.0
      npm ERR! A complete log of this run can be found in:
      npm ERR! /root/.npm/_logs/2024-01-07T15_55_27_397Z-debug.log
      can sombady pleas tel my what i have to enter so its always isdownloading the lates version ?
      p.s i got the metod from this site file://///diskstation/externe%20schijf%201/bouw%20projecten/bouwprojeckt%20arcade%20machien/Retropie%20+%20Homebridge%20on%20Raspberry%20Pi%202%20Model%20B.htm
        mitu Global Moderator @compukit
        The error is pretty clear, you need a newer Node version.
        Ayway, not sure how this is related to RetroPie, so you should consult the Homebridge docs and see if you have installed all the correct pre-requisites (Node, for instance).
          compukit @mitu
          @mitu wel iwalk trou somting on a page.
          and wel its says its foor the pi2 and i use a pi 3b+ bad it workd.
          (old pi 3b+
          bad the site is https://gist.github.com/sloyless/fe07bc010ab5c087d2191288d9114297.
            @compukit Can't understand what you're saying, but if it worked - great.
              compukit @mitu
              @mitu whel it was working when i first use it zo 4 or 5 years ago bad now it dosend work
