    NeoGeo CD - Romset is unknown. Help?
    neogeo cdraspberrypi 4romset
    9 Posts 4 Posters 7.8k Views
      Danrancan
      I am trying to get my NeoGeo CD roms to work on retropie on a Raspberry Pi 4. I have put the bios files in the "BIOS" directory on my roms disk. I have also put the neogeocd roms in the neogeo roms folder.
      When I try to load the rom on my Raspberry Pi 4, I get the following message:
      Romset is unknown. THIS IS NOT A BUG ! If you don't understand what this message means, then you need to read the arcade and FBNeo documentation at [https://docs.libretro.com](https://docs.libretro.com).
      I went to the link it sugested and didn't find any relevant info. Could someone please explain a step by step instruction to get Neogeo CD roms working on retropie?
      Thanks.
      windgW mituM B 3 Replies Last reply Reply Quote 0
      • windgW
        windg @Danrancan
        @Danrancan
        Try to launch the game with verbose logging enable and add here the runncommand.log file with the help of pastebin.com .
        How to launch the game with verbose logging : https://retropie.org.uk/docs/Runcommand/#launch-with-verbose-logging
          mitu Global Moderator @Danrancan
          @Danrancan said in NeoGeo CD - Romset is unknown. Help?:
          https://docs.libretro.com/library/fbneo/#how-do-i-launch-a-neogeo-cd-game. RetroPie already configures the 'subsystem' for FBNeo, you just need to copy the correct .cue/.bin files to the neogeo folder, then - when launching the game - use the runcommand menu to choose the lr-fbneo-neocd emulator.
            barbudreadmon @Danrancan
            There are relevant infos though : https://docs.libretro.com/library/fbneo/#how-do-i-launch-a-neogeo-cd-game
            Long story short, you tried launching a neogeo cd game as if it was an arcade romset.
            As @mitu said, retropie's lr-fbneo-neocd is a shortcut for running FBNeo with the --subsystem neocd argument, which is one of the 3 methods to launch neogeo cd games with FBNeo.
            D 2 Replies Last reply Reply Quote 1
              Danrancan @windg
              @windg said in NeoGeo CD - Romset is unknown. Help?:
              pastebin.com
              Where can I find the
              runncommand.log
              file? What is the file location of this?
                Danrancan @barbudreadmon
                @barbudreadmon I thought this might be a bios issue but you are telling me its not. Cool. Does NeoGeo CD Even need a bios? If so where do I put it and what is the name of the bios file?
                  @barbudreadmon said in NeoGeo CD - Romset is unknown. Help?:
                  I forgot to mention, My Neo Geo CD Roms are in .chd format. Could that be an issue?
                  windgW 1 Reply Last reply Reply Quote 0
                  • windgW
                    windg @Danrancan
                    @Danrancan Yes, lr-fbneo-neocd doesn't support .chd files.
                    The path for the log file is this : /dev/shm/runcommand.log
                    You can install lr-neocd from experimental packages that support chd files. To use this emulator you have to do 2 steps :
                    1. Create a folder named neocd in your BIOS folder and add there the bios files : neocd.zip , neocdz.zip .
                    2. Install lr-neocd emulator from experimental packages.
                    Don't forget to choose the emulator from the runcommand menu.
