    Wire-Connection between two Retropie consoles
    multiplaying2 player setup
    4 Posts 2 Posters 312 Views
    • Y
      yon100
      Hi,
      We have two Retropie consoles that we have built (Raspberry Pie 4B).
      I wonder if there is a way to connect between them so that one of them will be the master and the other the slave, enabling to play 2-players games.
      Thank you,
      Yonatan
        Something like Netplay ?
        • Y
          yon100
          Is there a possibility to use Netplay simply by connecting the two Pies with LAN cable?
            mitu Global Moderator @yon100
            @yon100 said in Wire-Connection between two Retropie consoles:
            Yes, as long as the 2 Pi have a network connection, Netplay doesn't care about the medium used (WiFi/Ethernet/Bluetooth/etc.).
