    No Sound with Amiberry (HDMI)
    amiberrysound issue
    11 Posts 4 Posters 2.1k Views
    • 1
      10vorne
      I'm not sure if it has to do with an update or the sound output on HDMI, but with Amiberry, I no longer have sound. All other emulators run normally via HDMI. I haven't played Amiga games in a while and I definitely had sound. I read online that some people had problems after switching from the headphone output to HDMI. However, HDMI is actually the output of choice as a sound output in my current setup. What could I try to persuade the Amiberry to use sound via HDMI?
      RapidEdwin08R 1 Reply Last reply Reply Quote 0
      • RapidEdwin08R
        RapidEdwin08 @10vorne
        @10vorne Try to manually edit the config file:
        /opt/retropie/configs/amiga/amiberry/conf/amiberry.conf
        default_soundcard=1
        Raspberry Pi B, Pi B+, Pi2 B, Pi3 B, Pi3 B+, Pi Zero W, Pi4 (4GB/8GB), Pi5 (8GB/16GB), Pi Zero 2 W, GPi V1, minisforum GK50 / RetroPie 4.8.x
        1 1 Reply Last reply Reply Quote 0
        • 1
          10vorne @RapidEdwin08
          Unfortunately that didn't help. I also tried out different games, both whdload and adf files. Anyone else have an idea what I could test?
            Please add some info about your system, as asked in https://retropie.org.uk/forum/topic/3/read-this-first. Include the version of RetroPie and Amiberry you have installed.
            • 1
              10vorne @mitu
              Below is the most important information, if more is needed, I'll look for it too:
              Raspberry Pi 3 Model B Rev 1.2
              Amiberry v 5.6.6
              Retropie 4.8.6
              After the tip with the amiberry.conf didn't help, I used the headphone jack output for Amiberry. Then I had sound, regardless of whether I had set 0 or 1 for the default sound card. The other emulators all ran a sound signal via HDMI.
              roslofR 1 Reply Last reply Reply Quote 0
              • roslofR
                roslof @10vorne
                @10vorne said in No Sound with Amiberry (HDMI):
                Was an issue for me originally. Try this:
                • Run the +Amiberry script (or Launch game and hit F12 to view options)
                • Select Sound (left column)
                • At the very top, there's a pulldown. Tap it to change options
                This was a problem for me because it defaulted to my DualShock 4 Controller. For you, might be because the wrong hdmi port is selected.
                Change it, select "Configurations", save it, relaunch it and hopefully the issue will be solved.
                • 1
                  10vorne @roslof
                  @roslof Uh...my USB-Keyboard got no F12 Key....only F10.
                  • roslofR
                    roslof @10vorne
                    It was an option. You can just run the Amiberry script.
                    • 1
                      10vorne @roslof
                      @roslof Just so we understand each other properly. I wasn't aware that you have options when you start the Amiberry+ script. But when I do that, all I get is a screen with the large floppy disk going into the drive. Is there another way to get into these options other than F12? Otherwise I'll have to look into getting another keyboard.
                        mitu Global Moderator @10vorne
                        @10vorne I think the RetroArch hotkey shortcut for the quick menu (Hotkey Enable + X) might work. You can also modify the key that opens up the menu (from the default of F12) in amiberry.conf.
                        • 1
                          10vorne @mitu
                          @mitu Hotkey + X worked, changed Sound to HDMI, perfect. Thank you both!
