    MKDD Tint Issue RPI5
    lr-dolphinmkdddoubledashvulkandrivers
    175 Posts 11 Posters 66.0k Views
    • abjA
      abj @AwesomeKingClem
      @AwesomeKingClem
      Sorry, i am out of ideas.
      `Please be patient, my English is not very good.`
      AwesomeKingClemA 2 Replies Last reply Reply Quote 0
      • AwesomeKingClemA
        AwesomeKingClem @abj
        @abj Meh, I will try to find what I can. I greatly appreciate your assistance! Thank you so much!
        Pi Model: Pi 5
        Power Supply: Official Pi 5 Power Supply
        RetroPie Version: 4.8.6
        Built From: retropie_setup.sh script on Raspbian official full x64 img
        Devices: N64 Controller (2)
        Help needed!
        https://retropie.org.uk/forum/topic/35172/mkdd-tint-issue-rpi5
        • AwesomeKingClemA
          @abj Definitely could've used this earlier :P
          https://retropie.org.uk/forum/topic/30541/dolphin-emulator-running-on-rp4b-64bit
          Pi Model: Pi 5
          Help needed!
          • retropieuser555R
            retropieuser555 @AwesomeKingClem
            @AwesomeKingClem Did that dolphin fork install for you? I get various errors where it's looking for a different version of pangocairo even though libpangocairo-1.0-0 is already installed by default
            Pi 5 4GB
            • AwesomeKingClemA
              AwesomeKingClem @retropieuser555
              @retropieuser555 I don’t know yet. I am finally getting around to finishing RetroPie-related tasks, so just give me a bit to try it out. For real this time, promise!
              Pi Model: Pi 5
              Help needed!
              • AwesomeKingClemA
                @retropieuser555 I looked through Ishiiruka, and the difference between it and Dolphin is that Ishiiruka uses the EGL OpenGL interface. The question is, would it be possible to set up EGL on lr-Dolphin or Dolphin natively? I mean, the Mesa drivers for the Raspberry Pi use many different rendering interfaces, including EGL. It even uses EGL to run a 3D interface in the first place.
                Edit: Guess what I found! https://docs.libretro.com/development/cores/core-specific/ishiiruka/ @mitu Ideas?
                Edit the Sequel: Is this going to be a problem? https://www.reddit.com/r/EmulationOnAndroid/comments/ji84ai/a_very_important_note_on_dolphin_ishiruka_read_if/
                Pi Model: Pi 5
                Help needed!
                • retropieuser555R
                  @AwesomeKingClem it's upto you, but reading that about it having shady potentially malicious code I'm out on testing that version. Will just wait for Mesa to be developed further so Vulkan or openly 3.3 is supported on pi 5.
                  Pi 5 4GB
                  AwesomeKingClemA 1 Reply Last reply Reply Quote 0
                  • AwesomeKingClemA
                    @retropieuser555 Well, I mean it’s officially supported..?
                    https://github.com/libretro/Ishiiruka
                    Pi Model: Pi 5
                    Help needed!
                    • ExarKunIvE
                      ExarKunIv @AwesomeKingClem
                      @AwesomeKingClem it kinda is but it has not been updated in 4 years. So it obviously it's out of date.
                      And since Windows x64 - Visual Studio 2017 is stated in the documents. I don't think it will work on arm
                      • AwesomeKingClemA
                        AwesomeKingClem @ExarKunIv
                        @ExarKunIv I do understand what you mean by it being outdated, but it says the same thing for Dolphin anyways:
                        https://docs.libretro.com/development/cores/core-specific/dolphin/
                        Pi Model: Pi 5
                        Help needed!
                        • ExarKunIvE
                          @AwesomeKingClem ok. I would not know. I didn't look at all the docs
                          You can always try to build it your self and see what it does.
                          Waiting for someone to make a script for it is probably going to be a bit. Most people are happy with just using dolphin.
                          I get you want the best outcome for the games you are having issues with. And it's cool you found this. But the devs have other things going on. So trying for a new GC emu is not high on the list
                          • AwesomeKingClemA
                            @ExarKunIv
                            I'm a perfectionist. Did that answer your question? :P
                            Pi Model: Pi 5
                            Help needed!
                            • AwesomeKingClemA
                              @ExarKunIv Since it is an official lib core, I may give it a try. I just need to do some more research first.
                              Pi Model: Pi 5
                              Help needed!
                              • AwesomeKingClemA
                                AwesomeKingClem @AwesomeKingClem
                                @AwesomeKingClem I have overall decided to avoid the Ishiiruka core, but I think I have another option that could fix the issue. Unfortunately, my micro hdmi to hdmi converter broke recently, so if someone could test if it works for me, I would appreciate it.
                                Graphics -> Enhancements -> Color-Correction
                                It apparently arrived in a recent Dolphin update, and it may fix my issue, but as I said, I can't access my Raspberry Pi 5 until I get a new hdmi converter. Appreciate it!
                                Pi Model: Pi 5
                                Help needed!
                                abjA 1 Reply Last reply Reply Quote 0
                                • abjA
                                  @AwesomeKingClem
                                  I try with Resident Evil 4 that have the same issue but no luck.
                                  This is the real issue that we would hope to get a fix: https://gitlab.freedesktop.org/mesa/mesa/-/issues/10250 .
                                  AwesomeKingClemA 1 Reply Last reply Reply Quote 1
                                  • AwesomeKingClemA
                                    @abj Well that definitely narrows it down. Back to the grind 🫡
                                    Pi Model: Pi 5
                                    Help needed!
                                    • AwesomeKingClemA
                                      Here's all the current sources that I rounded up from this "thread" (what else do you call it, anyway?) for personal use. I apologize if this counts as bumping a "thread"...
                                      Pastebins:
                                      https://pastebin.com/EjiAguvd
                                      https://pastebin.com/jxu3xeTv
                                      Other Solutions:
                                      https://github.com/dolphin-emu/dolphin/commit/dc08b73db19b8d59ec9ba373a4fb8d7d8639c9e3
                                      Ishiiruka:
                                      Issue Reports:
                                      https://bugs.dolphin-emu.org/issues/13416
                                      Pi Model: Pi 5
                                      Help needed!
                                      • AwesomeKingClemA
                                        @AwesomeKingClem
                                        Here are some new links that could also prove useful. I have a good feeling on the RasPi Forums thread.
                                        https://forums.raspberrypi.com/viewtopic.php?t=327210
                                        https://forums.dolphin-emu.org/Thread-vulkan-back-end-broken-latest-dev-builds-perhaps-by-newest-amd-drivers
                                        PDF with a VERY LONG link (Do not use this PDF if you don't trust it. I don't blame you..)
                                        Pi Model: Pi 5
                                        Help needed!
                                        • TPRT
                                          TPR @AwesomeKingClem
                                          @AwesomeKingClem said in MKDD Tint Issue RPI5:
                                          I reinstalled retroarch from source after editing the retroarch.sh file to show the option for vulkan.
                                          Can you please post the edit you made to the retroarch.sh file? Sounds like this is something I need to do. Thank you.
                                          • AwesomeKingClemA
                                            AwesomeKingClem @TPR
                                            @TPR
                                            Sure, just give me a couple hours.
                                            Edit: Here ya go.
                                            https://pastebin.com/FXLMdm9s
                                            Pi Model: Pi 5
                                            Help needed!
                                            TPRT G 2 Replies Last reply Reply Quote 0
