    Problem with lr-flycast installation
    lr-flycastretropie menu
    5 Posts 2 Posters 1.1k Views
    • Lord VekL
      Lord Vek
      Hello,
      So, I installed lr-flycast from the Retropie-setup/manage packages and I put the two BIOS files inside BIOS/dc folder. Then I put a game in .chd format inside the dreamcast folder. But, I don't see a Dreamcast category on the Retropie menu with the other emulators. What I did wrong?
      abjA 1 Reply Last reply Reply Quote 0
      • abjA
        abj @Lord Vek
        @Lord-Vek
        Please add more info : https://retropie.org.uk/forum/topic/3/read-this-first
        `Please be patient, my English is not very good.`
        Lord VekL 1 Reply Last reply Reply Quote 0
        • Lord VekL
          Lord Vek @abj
          @abj Raspberry Pi 400 with official transformer. Retropie 4.8.6. What other info you require?
          • abjA
            abj @Lord Vek
            @Lord-Vek
            Try to reset ownership permissions for the rom folder.
            RetroPie-Setup -> Configuration/Tools -> resetromdirs.
            Try also to reinstall the core and if you can, try another game not in chd format.
            • Lord VekL
              Lord Vek @abj
              @abj OK, solved. Upon reinstalling I got a message to copy the es_systems.gfg from the etc/ folder to opt/configs/all/emulationstation/
              Thanks for your help! Be well!
