    System Volume Resets to 0, Using HDMI to TV for Audio
    pi 4baudio outputaudio problemhdmi audio
    12 Posts 4 Posters 2.9k Views
      Swordmaster4321
      Hello!
      I am having issues with the volume in EmulationStation. It was previously working fine, but then I updated Raspberry Pi packages and updated RetroPie, and now the audio is no longer working. The system volume setting in ES keeps resetting to 0. I opened the audio setting in the RetroPie menu, and it says the audio output is (ALSA). I changed it to HDMI, but then when I go back to the audio settings it goes back to ALSA. I have no clue what caused this issue.
      Pi Model: RPI4B 2GB
      Power Supply used: 5 Volts 3 Amps
      RetroPie Version Used: 4.8
      Built From: Official Raspberry Pi Imager
      USB Devices connected: Keyboard, Xbox Elite Series 2 controller via USB-C
      Controller used: "Generic Xbox Gamepad"
      I will supply any other information if it is necessary 👍.
      • abjA
        abj
        Try this to be sure that everything have the default settings:
        RetroPie-Setup > audio > Hdmi .
        and restart the EmulationStation.
        Press the start button, while you are in Emulationstation menu, the sound settings must be:
        Audio card : Default
        Audio Device: HDMI.
        `Please be patient, my English is not very good.`
          Swordmaster4321 @abj
          @abj All the Emulationstation settings are set correctly, but whenever I go to RetroPie->Audio, it says the output is ALSA, no matter how many times I set it and restart ES. The volume still resets to 0 every time I exit and re-enter the ES menu though.
          • abjA
            abj
            Do you have install the Desktop?
            Try to run the following commands and add here the output results:
            aplay -l
            amixer
              @abj Yes, I have installed the desktop.
              Here are the results:
              aplay - l:
              This command appears to have broken my terminal. It has been 20 minutes and there still isn't an output.
              amixer:
              Simple mixer control 'Master',0
                Capabilities: pvolume pswitch pswitch-joined
                Playback channels: Front Left - Front Right
                Limits: Playback 0 - 65536
                Mono:
                Front Left: Playback 65536 [100%] [on]
                Front Right: Playback 65536 [100%] [on]
              Simple mixer control 'Capture',0
                Capabilities: cvolume cswitch cswitch-joined
                Capture channels: Front Left - Front Right
                Limits: Capture 0 - 65536
                Front Left: Capture 65536 [100%] [on]
                Front Right: Capture 65536 [100%] [on]
              abjA mituM 2 Replies Last reply Reply Quote 0
              • abjA
                abj @Swordmaster4321
                @Swordmaster4321
                Try to uninstall pulseaudio from here:
                RetroPie => RetroPie Setup => Configuration/Tools => rasbiantools => Choose option 3 ( remove some uneede... ) and restart.
                After that, make sure that you have the default settings that i post above.
                DarksaviorD 1 Reply Last reply Reply Quote 1
                  mitu Global Moderator @Swordmaster4321
                  @Swordmaster4321 said in System Volume Resets to 0, Using HDMI to TV for Audio:
                  aplay - l:
                  There's no space between - and l (lowecase L). I think you've added a space and the command expects some input from you (which is not coming). You can usually end every terminal launched command by pressing Ctrl + C.
                  • abjA
                    abj
                    Sorry, my bad i correct it.
                      Swordmaster4321
                      The audio is working now! Thank you! The last thing I'm wondering is why pulseaudio messes the whole thing up.
                        Swordmaster4321
                        And while we're here... is there a way to make scrolling between systems in the dashboard a lot smoother?
                        10fps isn't really cutting it for me lol
                          Don't run the system at 4k video resolution ? By default, 4k is diplayed at 30fps by the Pi4 unless you configure the HDMI output to run at 60fps with the hdmi_enable_4kp60 option (see here).
                          • DarksaviorD
                            Darksavior @abj
                            @abj Thanks. This fixed the audio for me.
                            On my unsupported pi5 setup, switching to the Pegasus frontend killed the audio, and switching back to ES was not fixing it.
