    NO SOUND - Raspberry Pi Zero 2W + Retroflag GPi Case
    zero 2wgpi caseno sound
    3 Posts 2 Posters 617 Views
      corny
      Hello, I am struggeling with the GPi Case (B-Ware) that I got.
      1. I Install the Retropie via Raspberry Pi Imager for the correct model.
      2. I install the patch for the Display from the official Retroflag Servers
      3. wpa_applicant.conf and ssh
      4. I start the GPi and everything runs good, except that I dont have any soundcard detected.
      I always get this error:
      here is my config.txt
      # http://www.raspberrypi.org/documentation/configuration/config-txt.md
      #hdmi_safe=1
      #disable_overscan=1
      #overscan_left=16
      #overscan_right=16
      #overscan_top=16
      #overscan_bottom=16
      # overscan.
      #framebuffer_width=1280
      #framebuffer_height=720
      #hdmi_force_hotplug=1
      #hdmi_group=1
      #hdmi_mode=1
      #hdmi_drive=2
      # no display
      #config_hdmi_boost=4
      # uncomment for composite PAL
      #sdtv_mode=2
      #arm_freq=800
      #dtparam=i2c_arm=on
      #dtparam=i2s=on
      #dtparam=spi=on
      # Uncomment this to enable the lirc-rpi module
      #dtoverlay=lirc-rpi
      dtparam=audio=on
      #config_hdmi_boost=0
      # force hdmi while the tv can take time before sending the signal on the hdmi output
      #sdtv_mode=2
      # uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      # uncomment if you don't want the rainbow at startup
      disable_splash=1
      # default CEC name
      cec_osd_name=recalbox
      # Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=512
      avoid_safe_mode=1
      kernel=zImage
      #dtparam=audio=on
      display_rotate=1
      dtoverlay=dpi24
      overscan_left=0
      overscan_right=0
      overscan_top=0
      overscan_bottom=0
      framebuffer_width=320
      framebuffer_height=240
      enable_dpi_lcd=1
      display_default_lcd=1
      dpi_group=2
      dpi_mode=87
      dpi_output_format=0x6016
      #hdmi_timings=320 0 28 18 28 480 0 2 2 4 0 0 0 60 0 32000000 6
      hdmi_timings=240 1 38 10 20 320 1 20 4 4 0 0 0 60 0 6400000 1
      dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
      disable_pvt=1
      disable_audio_dither=1
      dtoverlay=pwm-audio-pi-zero
      Please help!
        Try to use the configuration file posted in this topic.
          corny @mitu
          I use this config file now and it works:
          # http://rpf.io/configtxt
          #hdmi_safe=1
          #disable_overscan=1
          #overscan_left=16
          #overscan_right=16
          #overscan_top=16
          #overscan_bottom=16
          # overscan.
          #hdmi_group=1
          #hdmi_mode=1
          #hdmi_drive=2
          # no display
          #sdtv_mode=2
          #arm_freq=800
          #dtparam=i2c_arm=on
          #dtparam=i2s=on
          #dtparam=spi=on
          # Uncomment this to enable infrared communication.
          dtparam=audio=on
          [pi4]
          # Enable DRM VC4 V3D driver on top of the dispmanx display stack
          dtoverlay=vc4-fkms-v3d
          max_framebuffers=2
          [all]
          #dtoverlay=vc4-fkms-v3d
          gpu_mem_256=128
          gpu_mem_512=256
          gpu_mem_1024=256
          overscan_scale=1
          #Pi Zero 2 W GPi Config
          dtoverlay=audremap,pins_18_19,swap_lr
          display_rotate=1
          dtoverlay=dpi24
          overscan_left=0
          overscan_right=0
          overscan_top=0
          overscan_bottom=0
          enable_dpi_lcd=1
          dpi_group=2
          dpi_mode=87
