    Sound Sample Directory for using fbneo as default for Arcade ROMs?
    mame samplesmame emulatorfba mamefbneohelp
    4 Posts 2 Posters 1.3k Views
      thewillrussell
      This is a follow up a post from a topic I deleted from yesterday.
      I have the default emulator set to fbneo for Arcade Roms so I can be able to save high scores. MAME2003 wouldn't let me. But my problem is the sound samples don't work with fbneo. How do I create the sound directory for Arcade Sound Samples for using fbneo for Arcade MAME Roms?
        barbudreadmon @thewillrussell
        @thewillrussell https://docs.libretro.com/library/fbneo/
          thewillrussell @barbudreadmon
          @barbudreadmon I looked at the directory guide on there. It fixed the sound sample issues on Mario Bros but still not Donkey Kong or Q Bert. They should all work since I have them all in the directory.
            @thewillrussell Then the samples you are using are wrong.
            As for romsets, make sure the samples you are using are meant for the arcade emulator you are using.
