    problems with controls
    controller
    2 Posts 2 Posters 212 Views
    • Z
      zipino82
      good evening, I'm new, I have a problem with the games, a state slot message appears every time I push the skip button, could you tell me what the problem is, thanks
      PiBoyyyP 1 Reply Last reply Reply Quote 0
      • PiBoyyyP
        PiBoyyy @zipino82
        @zipino82 Could you please provide more info about your problem? If you're using a keyboard, just remember F2 saves your state and F4 loads it.
        If you're strong
        You can fly
        You can reach the other side
        Of the rainbow...
