    How to get my (non-bluetooth) wireless headphones to work on retropie
    audioheadphonesissue
    2 Posts 2 Posters 884 Views
    • exitkioskmodeE
      exitkioskmode
      Im attempting to use my Hyper X Cloud II wireless headphones on my pi4 Retro Pie build. Instead of using Bluetooth, the headphones use a USB dongle to connect a device, from which it sends the audio signal. When researching how to connect a wireless headset to my Pi I could only find results for Bluetooth. I have already tried to switch my audio to "headphones" under the audio section of the config menu, and I'm not sure where else to look to be able to enable my headphones.
      why do I keep running into problems
        Please add some info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        As far as Linux (and RetroPie) is concerned, your 'headphones' are just an USB audio card - disable the onboard audio and they should be come the default audio card on the system.
