    Sound Not Working At All
    sound issue
    11 Posts 3 Posters 1.9k Views
      BL4CKH0L3H34RT
      The other day I set up my pi 5 with RetroPie. Everything works fine with the exception of sound. Sound will not output whatsoever and I've spent the last 2 days frantically searching for any solution to my problem to no avail. Every time I lauch a game it spits out the error message for half a second "AudioManager Error - Unable to open SDL audio: alsa: Unsupported audio format"
      I'm attempting to use HDMI for the sound, and sound does work on the TV, I have tested with other devices. The version of RetroPie I'm using is 4.8.7.
      • abjA
        abj
        Did you change the audio to HDMI0 from raspi-config ?
        `Please be patient, my English is not very good.`
          BL4CKH0L3H34RT @abj
          @abj Yeah I have. Did it again just to check. Also when I go to Advaced Settings>Audio Config it says "No audio systems installed"
          • abjA
            abj
            I don't know what is wrong.
            Did you install RetroPie on top of Bookworm Lite (recommended) or full Desktop?
              BL4CKH0L3H34RT @abj
              @abj I installed it on top of lite
              abjA 1 Reply Last reply Reply Quote 0
              • abjA
                abj @BL4CKH0L3H34RT
                @BL4CKH0L3H34RT
                Try this to be sure that everything have the default settings:
                RetroPie-Setup > audio > Hdmi 0.
                and restart the EmulationStation.
                Press the start button, while you are in Emulationstation menu, the sound settings must be:
                Audio card : Default
                Audio Device: HDMI.
                If you have install the desktop from the RetroPIe setup script then ,
                try to uninstall pulseaudio from here:
                RetroPie => RetroPie Setup => Configuration/Tools => rasbiantools => Choose option 3 ( remove some uneede... ) and restart.
                After that, make sure that you have the default settings that i post above.
                  BL4CKH0L3H34RT @abj
                  @abj I've tripple checked, I have all of the settings set to those.
                  • abjA
                    abj
                    Try to run this commands and add the results here:
                    aplay -l
                    Make sure that you are using the HDMI port near the PSU port.
                    Also. if you have a second Hdmi cable or TV, test and there please .
                    I reinstall RetroPie, just in case that something change recently, but it wasn't possible to reproduse the issue.
                      BL4CKH0L3H34RT @abj
                      @abj I'm using the correct HDMI port, and I've checked on a seperate TV and the issue still persists. Here's the result of the aplay -l command:
                      0: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
                      subdevices: 1/1
                      subdevice #0: subdevice #0
                      1: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
                      subdevices: 1/1
                      2: Controller [Wireless Controller], device 0: USB Audio [USB Audio]
                      subdevices: 1/1
                        Try these:
                        1. Do you have a $HOME/.asoundrc file ? Remove it and check if the audio works.
                        2. Check if you have the RetroPie Audio configuration file (which you'll get if you use the Audio menu in RetroPie) in /etc/alsa/conf.d/99-retropie.conf. If you don't have it, then re-configure the audio using the RetroPie's Audio entry (not with raspi-config).
                        3. Disconnect the PS4 controller. Do you get audio ?
                          BL4CKH0L3H34RT @mitu
                          @mitu Your first suggestion worked! Thank you so much!
