    problem with audio in retropie
    audio issues
    6 Posts 2 Posters 1.0k Views
    • Z
      zipino82
      hi good evening I have a problem with the audio in retropie I use a touchscreen display with HDMI with flat cable as in the photo and I also went to set the audio in HDMI but nothing tells me an error I also put these parameters in config.txt hdmi_force_edid_audio= 1
      max_usb_current=1
      hdmi_force_hotplug=1
      config_hdmi_boost=7
      hdmi_group=2
      hdmi_mode=1
      hdmi_mode=87
      hdmi_drive=1
        Please use Enligsh for your post title and also add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first.
        • Z
          zipino82 @mitu
          @mitu hi good evening I have a problem with the audio in retropie I use a touchscreen display with HDMI with flat cable as in the photo and I also went to set the audio in HDMI but nothing tells me an error I also put these parameters in config.txt hdmi_force_edid_audio= 1
          max_usb_current=1
          config_hdmi_boost=7
          hdmi_group=2
          hdmi_mode=1
          hdmi_mode=87
          hdmi_drive=1
          hdmi_cvt 800 480 60 6 0 0 0
            mitu Global Moderator @zipino82
            @zipino82 Please provide the info requested in the URL I mentioned, don't repeat the same info you posted. Modify your post to include an English title.
            • Z
              zipino82 @mitu
              @mitu I changed the title and can you see it?
                @zipino82 Yes, I can see it, thank you. Please also provide the rest of the info requested.
