    Help with Gpi Case 2w sound
    help me pleaseraspberry pi 0wretro piegpi case 2wsound issue
    1 Posts 1 Posters 326 Views
      mrh0twheels
      FYI, total noob here, don't be surprised if I don't understand anything. (Sorry.) I know that you guys have probably heard of this problem 3000 times before, but I feel like i've tried every solution under the sun, and none of them work. On boot, my Pi 0 W (Not to be confused with Pi 0 2W) equipped GPi case 2w makes some odd buzzing/screaming noises, with the noise getting slightly different with each line of code. (IDK if this is normal or not. Correct me if this is to be expected.) Then the sound gets a lot quieter, and then comes back about 3 seconds later. Once ES is booted, the sound cuts out almost completely. When I put my ear up to the speaker, I can just barely make out some glitchy version of whatever sound is playing. Any help is appreciated. Thanks in advance!
