    (Solved) Pi5 : USB audio issue
    usb audiopi5mixer
    17 Posts 3 Posters 3.9k Views
    • DTEAMD
      DTEAM
      Hi Mitu ,
      I have an issue with USB to 3.5mm audio and my Pi 5. It's seem to be detected but no sound in my headphones. Here's my setup. Do I do something wrong.
      Pi Model 5 (with homemade handheld)
      Power Supply used: 3.0A official Pi power supply
      RetroPie Version Used : 4.8.7
      Built From:Manual installation
      USB Devices connected: USB Audio (usb to 3.5 mm jack) + Teensy lc (for gamepad)
      Controller used: Teensy lc (for gamepad)
      Error messages received: mixer error for sound
      Guide used: https://github.com/RetroPie/RetroPie-Setup/pull/3792
      https://retropie.org.uk/forum/topic/30821/usb-audio-not-working
      Emulator: N/A
      How to replicate the problem: Try to use a USB headseT
      Retropie UI / Sound setting: Volume 100% , Audio Card : Default, Audio device Master
      config.txt
      #dtparam=i2c_arm=on
      #dtparam=i2s=on
      #dtparam=spi=on
      #dtparam=audio=on
      dtparam=audio=off
      # Additional overlays and parameters are documented
      # /boot/firmware/overlays/README
      # Automatically load overlays for detected cameras
      #camera_auto_detect=1
      # Automatically load overlays for detected DSI displays
      display_auto_detect=1
      # Automatically load initramfs files, if found
      auto_initramfs=1
      # Enable DRM VC4 V3D driver
      dtoverlay=vc4-kms-v3d
      max_framebuffers=2
      # Don't have the firmware create an initial video= setting in cmdline.txt.
      # Use the kernel's default instead.
      disable_fw_kms_setup=1
      # Run in 64-bit mode
      arm_64bit=1
      # Disable compensation for displays with overscan
      disable_overscan=1
      # Run as fast as firmware / board allows
      arm_boost=1
      [cm4]
      # Enable host mode on the 2711 built-in XHCI USB controller.
      # This line should be removed if the legacy DWC2 controller is required
      # (e.g. for USB device mode) or if USB support is not required.
      otg_mode=1
      #new
      disable_audio_dither=1
      hdmi_force_hotplug=1
      avoid_warnings=1
      hdmi_group=2
      hdmi_mode=1
      hdmi_mode=87
      hdmi_cvt=800 480 60 6 0 0 0
      dtparam=spi=on
      dtparam=i2c_arm=on
      DTEAMD mituM 2 Replies Last reply Reply Quote 0
      • DTEAMD
        DTEAM @DTEAM
        aplay -l
        card 0: Audio [TX 96Khz USB Audio], device 0: USB Audio [USB Audio]
          Subdevices: 1/1
          Subdevice #0: subdevice #0
        card 1: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
          Subdevices: 1/1
        card 2: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
          Subdevices: 1/1
        aplay -L
        https://pastebin.com/WAtARZHn
        • DTEAMD
          DTEAM @DTEAM
          /proc/asound/cards
           0 [Audio          ]: USB-Audio - TX 96Khz USB Audio
                                KTMicro TX 96Khz USB Audio at usb-xhci-hcd.0-2, full speed
           1 [vc4hdmi0       ]: vc4-hdmi - vc4-hdmi-0
                                vc4-hdmi-0
           2 [vc4hdmi1       ]: vc4-hdmi - vc4-hdmi-1
                                vc4-hdmi-1
          pi@retropie:~ $ amixer scontrols -c Audio
          Simple mixer control 'Headphone',0
          Simple mixer control 'Mic',0
          in ~/.emulationstation/es_settings.cfg:
          <string name="AudioCard" value="Audio" />
          <string name="AudioDevice" value="Headphone" />
          my asound.conf file
          defaults.headphone.!card 0
          defaults.mic.!card 0
            mitu Global Moderator @DTEAM
            @DTEAM said in Pi5 : USB audio issue:
            No sound in ... ? Emulators, EmulationStation, other test programs you have tried ?
            This is not a guide and it doesn't apply to your current situation, since the PR in question is about the built-in audio outputs on a Pi.
            The linked documentation page is still valid - https://retropie.org.uk/docs/Sound-Issues/#adding-a-custom-audio-device-audio-mixer. Did you follow the steps in the document to choose a Mixer device ? Remove any .asoundrc configuration file you may have in $HOME, it shouldn't be needed.
              r3dstar
              Not exactly the solution you are looking for, but my cabinet has 3.5mm speakers glued in so with the Pi 5 dropping the 3.5mm connection, found on of these. https://www.amazon.co.uk/BOWONG-Converter-HDMI2HDMI-Extractor-Projector/dp/B0BL6WRV3C/. Needs a power supply, but gives me the HDMI audio with no messing around with any drivers, options or settings.
              • DTEAMD
                DTEAM @mitu
                @mitu said in Pi5 : USB audio issue:
                Yes I did it. My two options seems to be Default and Master or HW and Headphone. Both doesn't work. I continue to dig it.
                When I choose default and Master, I got no error message (mixer, etc.) but no sound in my headphone.
                  The documentation page shows how to choose from one of the mixer device on the sound card, some of which may not be offered in EmulationStation options.
                  Do you get audio in emulators or using the ALSA speakter-test utility ?
                  DTEAMD 2 Replies Last reply Reply Quote 0
                  • DTEAMD
                    DTEAM @mitu
                    Not yet. What I got for now. I'll do a test
                    pi@retropie:~ $ pi@retropie:~ $ amixer scontrols -D default
                    Simple mixer control 'Master',0
                    Simple mixer control 'Capture',0
                    pi@retropie:~ $ amixer scontrols -D sysdefault
                    pi@retropie:~ $ amixer scontrols -D hw
                    pi@raspberrypi:~ $ amixer scontrols -D audio doesn't work. I must use preset value like default.
                    audio = my audiocard
                    • DTEAMD
                      DTEAM @mitu
                      No sound for both
                      Does dtparam affect it?
                      dtparam=audio=on
                        No. In fact almost all of the video/audio related params you added have the effect as they did before.
                        No sound for both
                        Did you remove any ALSA configuration ? What's the out[put ofspeaker-test ?
                        • DTEAMD
                          DTEAM @mitu
                          yes
                          with card = default and device = master (seems to be the good combo.... but no sound )
                          https://pastebin.com/hf8Na64X
                            @DTEAM I don't see an error in speaker-test output. Make sure the output isn't muted by any chance.
                            • DTEAMD
                              DTEAM @mitu
                              How can I see if it's muted or not ? The sound level is always at 100% in the EmulationStation UI or in the alsamixer UI
                                @DTEAM in alsamixer, the muted state is printed with an M underneath the volume slider. You can toggle the muted state by pressing m.
                                • DTEAMD
                                  DTEAM @mitu
                                  Good news, It finally worked, It was on mute by default (I didn't use my keyboard in Alsamixer).
                                  But now I have a new problem. I played with pulse audio in my "Audio UI" and now my Pi freeze all the time and I have no sound and no video. How can I reactivate Pulse Audio (now enable to create stream) . I already used "Reset to default" but nothing change. I lost options in my UI with my mess.
                                  How can I reset my audio setup
                                    Reset to default I think only applies to the ALSA settings and just removes any RetroPie configuration file. In your case, it's not going to do anything, since RetroPie didn't configure your USB gamepad.
                                    No idea, try to remove the packages you've installed and reboot.
                                    • DTEAMD
                                      DTEAM @mitu
                                      It works again. I re-install PipeWire and AudioPulse from rasPi config and everything works great. thanks for your support
