    Directional controls not working on USB DragonWise joystick with Daphne Dragons Lair
    daphne joystick
    1 Posts 1 Posters 255 Views
      camsen64
      I have a zero delay USB encoder that jstest identifies as a DragonWise input.
      The jstest works normally and I have adjusted the dapinput.ini for playthrough of Dragon Liar.
      My PS4 controller works as expected, but my home-built arcade stick just will not work and the joystick left, right, down and up never sends signals when playing. I spent some time just disconnecting the joystick and using all buttons, and the same result. The buttons and the axis work outside of the daphne game, but not while I'm playing it.
      Any suggestions would be greatly appreciated.
      BTW: I installed hypseus because I was running out of ideas, and I see quite a few new folders and ini files when I view the SD Card with winscp , but I have no idea how the daphne and hypseus are related to each other and whether they are supposed to be combined or separate. I would certainly appreciate any links to how it all works.
      Thanks,
