    Rpi zero w with Gpi Case no sound
    zerogpi caseaudio issuesaudio issuealsa error
    1 Posts 1 Posters 210 Views
    • L
      lalofwa
      Pi Model or other hardware: RPi Zero W with GPi Case (the first one released)
      RetroPie Version Used: v4.8
      Built From: RetroPie website
      USB Devices connected: none
      Controller used: GPi Case buttons
      Error messages received:
      ALSA lib confmisc.c:767:(parse_card) cannot find card '0'
      ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
      ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
      ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
      ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
      ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
      ALSA lib conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
      ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM default
      Hello! I have problems with RetroPie on my GPi Case in version 4.8; I have no sound anywhere. I installed the GPi-Patch from the RetroFlag page without success. I modified the config.txt file to remove the "#" from dtparam=audio=on, but I still don't get any results. I hope you can help me. I have another image with an earlier version of RetroPie (4.5), and the audio works correctly.
      This is my config.txt file.
      # http://www.raspberrypi.org/documentation/configuration/config-txt.md
      #hdmi_safe=1
      #disable_overscan=1
      #overscan_left=16
      #overscan_right=16
      #overscan_top=16
      #overscan_bottom=16
      # overscan.
      #framebuffer_width=1280
      #framebuffer_height=720
      #hdmi_force_hotplug=1
      #hdmi_group=1
      #hdmi_mode=1
      #hdmi_drive=2
      # no display
      #config_hdmi_boost=4
      # uncomment for composite PAL
      #sdtv_mode=2
      #arm_freq=800
      #dtparam=i2c_arm=on
      #dtparam=i2s=on
      #dtparam=spi=on
      # Uncomment this to enable the lirc-rpi module
      #dtoverlay=lirc-rpi
      dtparam=audio=on
      #config_hdmi_boost=0
      # force hdmi while the tv can take time before sending the signal on the hdmi output
      #sdtv_mode=2
      # uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      # uncomment if you don't want the rainbow at startup
      disable_splash=1
      # default CEC name
      cec_osd_name=recalbox
      # Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=512
      avoid_safe_mode=1
      kernel=zImage
      dtparam=audio=on
      display_rotate=1
      dtoverlay=dpi24
      overscan_left=0
      overscan_right=0
      overscan_top=0
      overscan_bottom=0
      framebuffer_width=320
      framebuffer_height=240
      enable_dpi_lcd=1
      display_default_lcd=1
      dpi_group=2
      dpi_mode=87
      dpi_output_format=0x6016
      #hdmi_timings=320 0 28 18 28 480 0 2 2 4 0 0 0 60 0 32000000 6
      hdmi_timings=240 1 38 10 20 320 1 20 4 4 0 0 0 60 0 6400000 1
      dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
      disable_pvt=1
      disable_audio_dither=1
      dtoverlay=pwm-audio-pi-zero
