    8BitDo Pro 2 / rPi 3 B+ / Controller NOT detected
    8bitdopro 2
    4 Posts 2 Posters 721 Views
      BOne72
      Hi ...
      I have an issue with getting my 8BitDo Pro 2 Wired gamepad to work in RetroPie . I get to the GUI, but somehow the controller's not detected . There's a green light flashing on the controller, exactly the first one from the left .
      It's a gamepad for Switch / Windows ...
      but on the retail supplier's web-page it was defined to work with PC / Android / XBox, etc . being kind of a universal controller ...
      I believe .
      Could it be an issue with power ...
      What would you think, would it make any difference if I had a externally powered USB - hub in between the gamepad and the rPi ?
      Thank You, for reading out ...
      BOne .
      • E
        Enderman330
        Try installing driver if any for the gamepad
          BOne72 @Enderman330
          @Enderman330
          Hi …
          It was an issue with power .
          After hooking up via ext . powered usb - hub the game pad got detected .
          Now …
          Something with audio ;
          Is it possible to use a usb - audio interface for game sounds . I have a Behringer’s UMC202HD .
          If yes, then do I need some extra drivers for it,
          cause in Linux it generally is working out-of-the-box .
          Thanks again,
          BOne .
          • E
            Enderman330 @BOne72
            @BOne72 I am happy that you have fixed your previous problem...
            I am not sure with the audio as I usually connect audio from my monitor as you know audio is also transmitted with video through HDMI cable.
            I think you must do some changes in your settings...
            Try checking Retopi-setup or raspberrypi-setup....
