    Can’t mount USB - Flash disk
    usb - sticknot mountingaccess files
    5 Posts 2 Posters 887 Views
      BOne72
      I can’t acces my USB - stick, that I have my game roms on . The drive is in FAT32 - format and I’ve created a retropie-mount folder in it .
      I have also tried a folder named retropie .
      Any help will come in hand .
      BOne .
        Please fill out the info requested in https://retropie.org.uk/forum/topic/3/read-this-first.
        Is the usbromservice package installed ?
          BOne72 @mitu
          @mitu said in Can’t mount USB - Flash disk:
          Yes, usbromservice package is installed / enabled .
          Still can't access files on it . It is detected, yes, but not able to access .
            mitu Global Moderator @BOne72
            @BOne72 said in Can’t mount USB - Flash disk:
            How do you know it's detected ? Does it show the contents if you look in the File Manager under the /mnt/usb0 folder ?
            Please also add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first.
              BOne72 @mitu
              It is displayed in /dev/disk/by-label, etc. as @RETROPIE and as @retropie, but nothing in /mnt/usb
              and I can't "mount" it, mean look into the device and the files in it .
