    Installing Retropie on top of Raspberry OS
    raspberry 4 bretropieraspberry osnew at thisnoobs+retropie
    26 Posts 6 Posters 8.6k Views
      SquidCoder
      Hey. I want to install Retropie on top of Raspberry OS. When I look online I only see people installing Retropie on Raspian OS. Raspian is pretty outdated so I need to make sure it is Raspberry OS. Please help. I don’t know a lot about this and any help would be greatly appreciated.
      • mituM mitu moved this topic from Projects and Themes on
      • ExarKunIvE
        ExarKunIv @SquidCoder
        @SquidCoder Here is a good set of instructions I have used
        https://github.com/danielfreer/raspberrypi5-retropie-setup
        Or here is a image that a fellow user made and posted
        https://retropie.org.uk/forum/post/298705
        Hope you this helps
          Use https://retropie.org.uk/docs/Manual-Installation/ as a starting point. The guide mentioned by @ExarKunIv is just an expanded copy of it.
          EDIT: is this is for installiing Dolphin on the Pi4, then don't bother, the Pi4 is quite underpowered to handle GC/Wii emulation.
            SquidCoder @ExarKunIv
            @ExarKunIv I see all of these for a pi5. I have a pi 4. Will it still work? Also, can you please explain to me what these links do?
            • ExarKunIvE
              @SquidCoder the guide will work the same way on a pi4 vs pi5
              use https://retropie.org.uk/docs/Manual-Installation/ since you are on the pi4
                @ExarKunIv does bullseye support retropie now or was that post you gave me the link for kinda old?
                • ExarKunIvE
                  @SquidCoder it does work on bullseye, but the devs are focused on bookworm since thats the most current main raspberry OS that raspberry pi is using.
                  so using bullseye something may or may not work. i dont know
                  bookworm is newer then bullseye FYI
                    @ExarKunIv Ok. Will bookworm work? If it doesn’t, can you give me the link to bullseye?
                    • sugarfreeS
                      sugarfree
                      I believe the next RetroPie image for the Raspberry Pi 4/3/2/0 will use Bullseye, since Bullseye has recently moved to legacy support.
                      S ExarKunIvE 2 Replies Last reply Reply Quote 0
                        SquidCoder @sugarfree
                        @sugarfree So how do I download this?
                        sugarfreeS 1 Reply Last reply Reply Quote 0
                        • sugarfreeS
                          sugarfree @SquidCoder
                          @SquidCoder
                          You can download the images from here: https://files.retropie.org.uk/images/weekly/. However, please note that they are development images and haven't been thoroughly tested. Therefore, I wouldn't recommend using them for daily use.
                            @sugarfree Ok. This looks like it will be very complicated. Can I upgrade the raspian os I put on my retropie to raspberry OS bookworm?
                            • sugarfreeS
                              sugarfree
                              It is not possible.
                                @sugarfree Ok. Would it be easier to build it on top of Ubuntu?
                                • ExarKunIvE
                                  ExarKunIv @sugarfree
                                  @sugarfree that might not be true
                                  i already asked what version the next RetroPie will be and was told it will be bookworm since that has Pi5 support
                                  https://retropie.org.uk/forum/topic/34627/raspberry-pi-5-official-announcement/426
                                  but who knows at this point
                                    @ExarKunIv So waht should I do? I am so lost and my head is swirling. How do I do this, and how long will it last? It seems like raspberry os has a new version ever few days and the version that I build will only last a little while. Should I wait until it is supported by bookworm or should I try now?
                                    sugarfreeS ExarKunIvE 2 Replies Last reply Reply Quote 0
                                    • sugarfreeS
                                      @SquidCoder
                                      Just download the latest stable version and enjoy your favorite old games: https://retropie.org.uk/download/
                                      • ExarKunIvE
                                        @SquidCoder since you are running a Pi4 just go with what @sugarfree suggests.
                                        i have a Pi4 running a the version that you just get from the RetroPie downloads and its still fine
                                        i stopped updating it about 9 months ago. i have mine offline so it does not need any security updates and all the systems are working fine for me. so no need to worry about updating to the most current versions on things.
                                        you can go mad trying to keeping everything up to date.
                                        as long as everything it working. then you are good to go
                                        start here
                                        https://retropie.org.uk/docs/First-Installation/
                                        then you do want to at least update at least once to get the latest at this time
                                        https://retropie.org.uk/docs/Updating-RetroPie/
                                          @ExarKunIv The version that comes with retropie is the outdated raspian OS. Meaning that many apps are not supported like pi-apps and pi commander.
                                          • ExarKunIvE
                                            @SquidCoder said in Installing Retropie on top of Raspberry OS:
                                            they are not designed to work with RetroPie to start with. at that point you are on your own.
                                            they are designed to work with a desktop as RetroPie does not use one or install one. you have to manual install the desktop your self from the menu
                                            S LolonoisL 2 Replies Last reply Reply Quote 0
