    need help to update retropie package script
    scripts update
    11 Posts 2 Posters 1.0k Views
    • W
      wsamael
      Hello I was made some script for auto install in old version of retropie and i wantmake another for a recent version.
      i was would launch package update update with a a command in a script in my old version with this commande
      "sudo bash ./RetroPie-Setup/retropie_packages.sh setup
      updatescript"
      but it's not work for recent veriosn . how can i update retropie package in recent version ?
      thanks for helping me ;)
        sleve_mcdichael @wsamael
        @wsamael said in need help to update retropie package script:
        updatescript
        In your post you wrote updatescript
        on a separate line but that's just a copy-and-paste error, right? Because it should all be on one line:
        sudo bash ./RetroPie-Setup/retropie_packages.sh setup updatescript
        (That's all typed as one line, even if the forum doesn't render it that way)
        Otherwise, that "should" work, as long as the command is ran from the $HOME directory. Try replacing the initial . with a ~ instead:
        sudo bash ~/RetroPie-Setup/retropie_packages.sh setup updatescript
        ...that should work from anywhere, since it references the home dir directly by the shortcut "~", rather than the relative path ".".
        Also you shouldn't need bash, since the script should be executable on its own:
        sudo ~/RetroPie-Setup/retropie_packages.sh setup updatescript
        • W
          wsamael @sleve_mcdichael
          @sleve_mcdichael
          I wrote in one line, it's work on older version but not in the recent version :(
          Thx for the ~, but it's not work. All my script has ok except this command. In change log on retropie 4.8 i saw
          "Improvement to RetroPie package management and updating" so something has change but what ;)
            @wsamael the command work on my system, just now. What error message you get, when you try?
            • W
              @sleve_mcdichael
              I don't have an error message, just that nothing happens when I click ok. and I return to the command prompt
              Are you on 4.8 ?
                @wsamael yes, 4.8.8
                • W
                  @sleve_mcdichael
                  this command works for update installed core
                  " sudo ~/RetroPie-Setup/retropie_packages.sh setup update_packages -y"
                  but this one do not work,
                  "sudo ~/RetroPie-Setup/retropie_packages.sh setup updatescript"
                  as you can see if i press ok i return to prompt command and nothing happened
                    It says the script was updated, and it was. What else would you like for to happen after that, besides command prompt?
                    • W
                      @sleve_mcdichael
                      after the prompt nothing happens as if I had quit retropie.
                      ok it's up to date but if I launch through the menu it still checks, there, it doesn't do anything
                      It's not supposed to quit retropie setup.
                      and even without being up to date it does the same
                        @sleve_mcdichael
                        That's how it's meant to work. The way you're doing here, retropie_packages.sh [package] [function] is used to call an individual specified function (example, the updatescript function of the setup package), and then exit.
                        If you want to go back to the menu after, you can run retropie_setup.sh after the updatescript function:
                        retropie_setup.sh
                        This is equivalent to doing:
                        retropie_packages.sh setup gui
                        I'm not sure what you mean, here. What does it check?
                        When you do it through the menu, after updatescript it does runs another function post_update which in turn runs an _update_hooks function, on every package that has one. Maybe this is what you mean that it "checks"?
                        ...I am not sure, but I think you can usually skip this step, since I think this is for doing a sort of "fixup" when, for example bringing RetroPie up to date from a very old version like 3.x updating to 4.x.
                        If you want to run it anyway:
                        retropie_packages.sh setup post_update
                        post_update also has a special "return function" that it can run another function after exit -- if that "return function" is gui_setup, then it goes right to the main menu. So instead of three commands for updatescript, post_update, and gui, you can do it in only two with:
                        retropie_packages.sh setup post_update gui_setup
                        (This is what actually happens, when you choose it in the menu.)
                        ...does any of this help?
                        • W
                          This post is deleted!
