    Exclude crt-pi shader from specific system. How?
    crt-pi shader
    4 Posts 3 Posters 1.5k Views
      Pyjamarama
      Hi all,
      I have set the crt-pi shader to affect all my emulators.
      How can I exclude the Game&Watch? i want no shader there.
      I went to RetroArch and removed the shader from the Game & Watch core but I still have scanlines.
      • FloobF
        Floob
        You could add this line
        video_shader_enable = false
        to the system specific retroarch.cfg in
        `/opt/retropie/configs/{system-name}/retroarch.cfg
        You could use this tool for that:
        https://github.com/retropie/retropie-setup/wiki/Configuration-Editor
          BuZz administrators
          This can be done from the configuration editor (from the retropie menu) - which avoids having to manually edit files (which could introduce problems). @Floob it would be best to recommend people use the configuration editor in cases like this, at least as the easiest option.
            Pyjamarama @BuZz
            Thank you!
