    Daphne Help?
    daphnedragons lairdvd-rom
    2 Posts 2 Posters 369 Views
      amtimes546
      Daphne is incredible in theory, but it has too many "dl21.txt" and "command.txt" files that need to go with the rom. I don't know what to do! I heard you can use the DVD "Dragons lair 20th anniversary" on Daphne, but I want to make sure before I shell out 20 bucks for a DVD.
      If anyone could fill me in on what needs to be put in these extra files (dl21.txt or whatever), that would be great!
      I'm using a Pi4 for Retropie and a MacBook for downloads and want to install Dragon's Lair 2.1. Just in case it helps! :)
        Please don't double post. You posted the same topic a couple of days ago already - this post will be locked and deleted later on.
        • mituM mitu locked this topic on
