    My SD card doesn't see my external drive now
    retropieextrernal driveusb rom servicepi4
    12 Posts 6 Posters 2.0k Views
      Retrodade
      Help please
      Retro-pie, pi4
      I tested another external drive, same.
      I tested another card on the drive and it loaded the external hard drive
      so, it's not the hard drive , it's the card
      I went into retro pie settings and re enabled USB rom service again
      still won't see the drive
      Question is can I manually add it to some text file?
      perhaps a shutdown caused this?
      no issues with the card itself, just won't see a drive,
      is this fixable?
      Thank you
        Please add some info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first. Include the information about your external drive.
          dukeforest @mitu
          Both my Pi4 and Pi5 stopped recognizing USB sticks after an update I did a few days ago!
          After updating the setup script and main core, they are not recognized even after rebooting
          https://retropie.org.uk/docs/Running-ROMs-from-a-USB-drive/
          I have followed this and re-configured the settings, but nothing has changed.
            Peeteris
            Same problem.
            After recent updates, external HDD with retropie-mount doesn't mount and nothing (except settings) shows on emulationstation.
            TPRT 1 Reply Last reply Reply Quote 0
            • TPRT
              TPR @Peeteris
              Same issue here. I updated setup-script today on my Pi 5, tried to update retroarch and my entire external hard drive seems to not be recognized. I even tried to re-enable USB Rom Service and that didn't work.
              So I guess I'll revert back to my old version until this obvious bug in the latest setup script gets fixed.
              • sugarfreeS
                sugarfree
                It was a bug that the devs fixed. Update retropie-setup script to fetch the latest version and reinstall the usbromservice package.
                TPRT D 2 Replies Last reply Reply Quote 0
                • TPRT
                  TPR @sugarfree
                  @sugarfree said in My SD card doesn't see my external drive now:
                  When was it fixed because I tried that yesterday and it didn't work.
                  sugarfreeS 1 Reply Last reply Reply Quote 0
                  • sugarfreeS
                    sugarfree @TPR
                    @TPR Few hours ago, see: https://github.com/RetroPie/RetroPie-Setup/commit/18c2b43000ec54d74ba016e0b8de654122377dba
                    TPRT R 3 Replies Last reply Reply Quote 1
                    • TPRT
                      TPR @sugarfree
                      Perfect! Thank you!
                      • TPRT
                        TPR @sugarfree
                        Just updated setup script and can confirm it works!
                          dukeforest @sugarfree
                          @sugarfree I have done the update on both Pi5 and 4 and it is working
                          Thanks.
                            Retrodade @sugarfree
                            @sugarfree THANK YOU!
                            this is solved
                            never would have thought updating the retro-pie set up script was how I lost the external drive loading.
                            i got busy for a few days, was wondering what to do, this am I was able to get on the forum, seen others having same issue after the update of set up script, then remembered "I did that too!" I seen it's been fixed and re did the update, now i have the drive loading again.
                            thanks for taking the time and adding this info!
                            also thanks to all others who commented advice
                            SOLVED!!
