    RetroPie Beta-RPi5 usbmount doesn't work
    usbmountpi5 usb
    4 Posts 2 Posters 374 Views
    • sugarfreeS
      sugarfree
      Raspberry Pi5
      Official PSU
      RetroPIe 4.8.8, manually installed on Pi OS Lite 64 bit
      Bootloader: Tue Jul 30 02:25:46 PM UTC 2024 (1722349546)
      Gamepad: Logitech F710
      Storage: exfat 128gb usb stick for roms.
      Hello. I looks that RetroPie can't read my external storage anymore. My setup is freshly installed few days ago. Here are some logs:
      lsusb:
      pi@retropie:~/RetroPie-Setup $ lsusb
      Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 003 Device 002: ID 046d:c21f Logitech, Inc. F710 Wireless Gamepad [XInput Mode]
      Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 001 Device 002: ID 1b1c:1a15 Corsair Voyager Slider Flash Drive
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      runncomand setup log :
      Log started at: Mon Sep  9 08:22:14 AM EEST 2024
      RetroPie-Setup version: 4.8.8 (82bbd5b)
      System: rpi5 (aarch64) - Debian GNU/Linux 12 (bookworm) - Linux retropie 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
      Installing dependencies for 'usbromservice' : USB ROM Service
      git clone --recursive --depth 1 --shallow-submodules --branch systemd "https://github.com/RetroPie/usbmount.git" "/home/pi/RetroPie-Setup/tmp/build/usbromservice/usbmount"
      Cloning into '/home/pi/RetroPie-Setup/tmp/build/usbromservice/usbmount'...
      HEAD is now in branch 'systemd' at commit 'c1698eefbbe3786668188be89edca5fed19f77d0'
      dpkg-buildpackage: info: source package usbmount
      dpkg-buildpackage: info: source version 0.0.24+1rpi
      dpkg-buildpackage: info: source distribution unstable
      dpkg-buildpackage: info: source changed by Jools Wills <buzz@exotica.org.uk>
       dpkg-source --before-build .
      dpkg-buildpackage: info: host architecture arm64
       debian/rules clean
      dh clean
      dh: warning: Compatibility levels before 10 are deprecated (level 9 in use)
         dh_clean
      dh_clean: warning: Compatibility levels before 10 are deprecated (level 9 in use)
       dpkg-source -b .
      dpkg-source: info: using source format '3.0 (native)'
      dpkg-source: info: building usbmount in usbmount_0.0.24+1rpi.tar.xz
      dpkg-source: info: building usbmount in usbmount_0.0.24+1rpi.dsc
       debian/rules build
      dh build
         dh_update_autotools_config
       debian/rules binary
      dh binary
         dh_testroot
         dh_prep
         dh_auto_install --destdir=debian/usbmount/
      dh_auto_install: warning: Compatibility levels before 10 are deprecated (level 9 in use)
         dh_install
      dh_install: warning: Compatibility levels before 10 are deprecated (level 9 in use)
         dh_installdocs
      dh_installdocs: warning: Compatibility levels before 10 are deprecated (level 9 in use)
         dh_installchangelogs
         dh_perl
         dh_link
         dh_strip_nondeterminism
         dh_compress
      dh_compress: warning: Compatibility levels before 10 are deprecated (level 9 in use)
         dh_fixperms
         dh_missing
      dh_missing: warning: Compatibility levels before 10 are deprecated (level 9 in use)
         dh_installdeb
      dh_installdeb: warning: Compatibility levels before 10 are deprecated (level 9 in use)
         dh_gencontrol
         dh_md5sums
         dh_builddeb
      dpkg-deb: building package 'usbmount' in '../usbmount_0.0.24+1rpi_all.deb'.
       dpkg-genbuildinfo -O../usbmount_0.0.24+1rpi_arm64.buildinfo
       dpkg-genchanges -O../usbmount_0.0.24+1rpi_arm64.changes
      dpkg-genchanges: info: including full source code in upload
       dpkg-source --after-build .
       signfile usbmount_0.0.24+1rpi.dsc
      dpkg-buildpackage: info: full upload; Debian-native package (full source is included)
      gpg: skipped "Jools Wills <buzz@exotica.org.uk>": No secret key
      gpg: dpkg-sign.zSk71azQ/usbmount_0.0.24+1rpi.dsc: clear-sign failed: No secret key
      dpkg-buildpackage: error: failed to sign usbmount_0.0.24+1rpi.dsc file: OpenPGP backend command cannot sign
      Selecting previously unselected package usbmount.
      (Reading database ... 88019 files and directories currently installed.)
      Preparing to unpack .../usbmount_0.0.24+1rpi_all.deb ...
      Unpacking usbmount (0.0.24+1rpi) ...
      Setting up usbmount (0.0.24+1rpi) ...
      Installing (binary) 'usbromservice' : USB ROM Service
      /opt/retropie/supplementary/usbromservice /home/pi/RetroPie-Setup/tmp/build/usbromservice/usbmount
      Configuring 'usbromservice' : USB ROM Service
      Log ended at: Mon Sep  9 08:22:18 AM EEST 2024
      Total running time: 0 hours, 0 mins, 4 secs
      systemctl status usbmount@dev-sda1:
      pi@retropie:~ $ systemctl status usbmount@dev-sda1
      ā— usbmount@dev-sda1.service
           Loaded: loaded (/lib/systemd/system/usbmount@.service; static)
           Active: active (exited) since Mon 2024-09-09 09:00:18 EEST; 4min 20s ago
          Process: 681 ExecStart=/usr/share/usbmount/usbmount add (code=exited, status=0/SUCCESS)
         Main PID: 681 (code=exited, status=0/SUCCESS)
              CPU: 82ms
      Sep 09 09:00:17 retropie systemd[1]: Starting usbmount@dev-sda1.service...
      Sep 09 09:00:17 retropie usbmount[836]: executing command: mount -texfat -onodev,noexec,noatime,uid=1000,gid=1000 dev/sda>
      Sep 09 09:00:18 retropie usbmount-10_retropie_mount-[899]: rsync -rtu /root/RetroPie/ /media/usb0/retropie-mount/ - retur>
        rsync error: some files/attrs were not transferred (see previo>
      Sep 09 09:00:18 retropie usbmount-10_retropie_mount-[900]: Mounting /media/usb0/retropie-mount over /root/RetroPie ...
      Sep 09 09:00:18 retropie usbmount-10_retropie_mount-[903]: mount -o bind /media/usb0/retropie-mount /root/RetroPie - retu>
        dmesg(1) may have more information after failed mount s>
      Sep 09 09:00:18 retropie systemd[1]: Finished usbmount@dev-sda1.service.
      lines 1-15/15 (END)
        Yes, it's a regression caused by https://github.com/RetroPie/RetroPie-Setup/commit/d67e88db2357836970a13615cff55b9b97defe1e.
          @BuZz fixed this part of the regression in https://github.com/RetroPie/RetroPie-Setup/commit/18c2b43000ec54d74ba016e0b8de654122377dba.
          @sugarfree can you update RetroPie-Setup and then re-install the usbromservice package to see if the issue is solved ?
          sugarfreeS 1 Reply Last reply Reply Quote 1
          • sugarfreeS
            sugarfree @mitu
            @mitu Thank you! It's working again
