    volume mixer error
    help fast
    21 Posts 5 Posters 6.4k Views
    • H
      hughp
      everytime my sound settings are headphones default card and alsa the volume resets to 0 after changing but i get volume in games.
        Please add some info about your setup, as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
        What is your exact question for the topic ?
        • H
          hughp @mitu
          @mitu a raspberry pi with a logitechis21 set of speakers and sub my question is how to get the volume slider unstuck it resets to 0 but i get volume in game i need help getting the slider unstuck
          R mituM 2 Replies Last reply Reply Quote 0
            Retrodade @hughp
            @hughp I have had this issue many times with newer retro pie.
            I never could fix it, hope yours gets solved
            With HDMI new seemed fine, but I use the headphone jack with speakers, only solution for me was stick with older retro pie.
            it's not a solution, I know
            hopefully your post will shed some light on this headphone jack no sound issue
            • H
              hughp @Retrodade
              @Retrodade i have sound in games =just the volume slider is stuck so i have to use the controls inside the machine
                mitu Global Moderator @hughp
                @hughp You've provided almost no information from the list in https://retropie.org.uk/forum/topic/3/read-this-first. What Pi model ? What RetroPie version and how did you install it ? Your speakers - how are they connected to the Pi ?
                • H
                  hughp @mitu
                  @mitu raspberry pi 4 retropie 4.8 used raspberry pi installer speakers use headphonejack
                    Arrafart
                    Hi, I have the same issue.
                    Plus, I have this error while loading each game.
                    Orange Pi zero 2w 4gb, Dietpi OS.
                    Oct 23 19:58:42 lvl0: VolumeControl::init() - Failed to find mixer elements!
                      mitu Global Moderator @Arrafart
                      @Arrafart said in volume mixer error:
                      Post the settings for audio that you have in EmulationStation (Card and Device). What version of DietPi ? Are you using PulseAudio/PipeWire for audio ? Is the audio working when you start a game/emulator ?
                      Please run the following commands and post the output:
                      amixer
                      aplay -l
                      aplay -L
                        Arrafart @mitu
                        @mitu Hi Mitu, thank you for the response!
                        I am running Dietpi OS v9.8.0 Armv8 Debian GNU/Linux 12 Bookworm
                        Device model : Orange Pi Zero 2W (aarch64)
                        Pulseaudio is installed, I've read elsewhere that it should connect to Alsa.?
                        I do have sound through HDMI output, no matter what settings in ES.
                        ES, Retroarch and Mupen64plus are fully functional, apart from the error.
                        Extra info, proper hardware/software setup for the sound on Orange Pi Zero 2w might be incomplete. If so, and this is an OS issue, i'll move back to the Dietpi forum :)
                        Hope this will already help identifying the issue:
                        dietpi@DietPi:~$ amixer
                        Simple mixer control 'Master',0
                        Capabilities: pvolume pswitch pswitch-joined
                        Playback channels: Front Left - Front Right
                        Limits: Playback 0 - 65536
                        Mono:
                        Front Left: Playback 26213 [40%] [on]
                        Front Right: Playback 26213 [40%] [on]
                        Simple mixer control 'Capture',0
                        Capabilities: cvolume cswitch cswitch-joined
                        Capture channels: Front Left - Front Right
                        Limits: Capture 0 - 65536
                        Front Left: Capture 65536 [100%] [on]
                        Front Right: Capture 65536 [100%] [on]
                        dietpi@DietPi:~$ aplay -l
                        card 0: audiocodec [audiocodec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0]
                        Subdevices: 1/1
                        Subdevice #0: subdevice #0
                        card 1: ahubi2s0 [ahubi2s0], device 0: ahub_plat-snd-soc-dummy-dai snd-soc-dummy-dai-0 [ahub_plat-snd-soc-dummy-dai snd-soc-dummy-dai-0]
                        Subdevices: 1/1
                        card 2: HDMI [HDMI], device 0: ahub_plat-i2s-hifi i2s-hifi-0 [ahub_plat-i2s-hifi i2s-hifi-0]
                        Subdevices: 1/1
                        dietpi@DietPi:~$ aplay -L
                        null
                        Discard all samples (playback) or generate zero samples (capture)
                        lavrate
                        Rate Converter Plugin Using Libav/FFmpeg Library
                        samplerate
                        Rate Converter Plugin Using Samplerate Library
                        speexrate
                        Rate Converter Plugin Using Speex Resampler
                        jack
                        JACK Audio Connection Kit
                        oss
                        Open Sound System
                        pulse
                        PulseAudio Sound Server
                        speex
                        Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
                        upmix
                        Plugin for channel upmix (4,6,8)
                        vdownmix
                        Plugin for channel downmix (stereo) with a simple spacialization
                        default
                        Playback/recording through the PulseAudio sound server
                        hw:CARD=audiocodec,DEV=0
                        audiocodec, CDC PCM Codec-0
                        Direct hardware device without any conversions
                        plughw:CARD=audiocodec,DEV=0
                        Hardware device with all software conversions
                        sysdefault:CARD=audiocodec
                        Default Audio Device
                        dmix:CARD=audiocodec,DEV=0
                        Direct sample mixing device
                        usbstream:CARD=audiocodec
                        audiocodec
                        USB Stream Output
                        hw:CARD=ahubi2s0,DEV=0
                        ahubi2s0, ahub_plat-snd-soc-dummy-dai snd-soc-dummy-dai-0
                        plughw:CARD=ahubi2s0,DEV=0
                        sysdefault:CARD=ahubi2s0
                        dmix:CARD=ahubi2s0,DEV=0
                        usbstream:CARD=ahubi2s0
                        ahubi2s0
                        USB Stream Output
                        hw:CARD=HDMI,DEV=0
                        HDMI, ahub_plat-i2s-hifi i2s-hifi-0
                        plughw:CARD=HDMI,DEV=0
                        sysdefault:CARD=HDMI
                        dmix:CARD=HDMI,DEV=0
                        usbstream:CARD=HDMI
                        HDMI
                        USB Stream Output
                          Arrafart
                          I was trying every setting yesterday and gave up. I gave up when it was set to: Default/Master
                          I logged in to double check and... No more error.
                            Mono:
                            Since the default Mixer control for the default audio card is named Master , this is what you should set as Audio Device. As it turns out, you already found this is the working option.
                              Arrafart @mitu
                              @mitu thank you for clarifying. If needed on a different device, I now know how to check it and replicate.
                              • H
                                hughp @Arrafart
                                @Arrafart i have this issue still and i need help its a black rasp pie 4 4gb running retro pie
                                  Arrafart @hughp
                                  @hughp for me it was finding the correct setting. Default/Master
                                  Try to replicate what @mitu said above. I was lucky to reboot with the correct setting by accident.
                                  I believe a reboot will be necessary ater each time you check it, but not sure.
                                  Again, I was lucky and Mitu was right the day after.
                                    No, a reboot is not necessary.
                                    • H
                                      hughp @mitu
                                      @mitu what do i need to do to fix my issue
                                        @hughp Change the Audio settings for Card in EmulationStation to Headphones ?
                                        • H
                                          hughp @mitu
                                          @mitu its on headphones
                                            @hughp No idea then. If the audio works in games, then the default device is set to headphone/analog on the system.
                                            amixer
                                            aplay -l
