    $md_inst string not working correctly when added against another string?v(lr-melondsds
    stringsndsmelonds
    10 Posts 4 Posters 598 Views
    • retropieuser555R
      retropieuser555
      I'm having an issue when writing a script to add a second string before the $md_inst script that generates for a retroarch game.
      function configure_lr-melondsds() {
          mkRomDir "nds"
          ensureSystemretroconfig "nds"
          local launch_prefix="XINIT-WM:"
          addEmulator 0 "$md_id" "nds" "$launch_prefix$md_insta/melondsds_libretro.so"
          addSystem "nds"
      This just gives me XINIT-WM:opt/retropie/libretrocores/lr-melondsds/melondsds_libretro.so
      Any idea what I'm doing wrong with the two strings to make them play nice?
      Pi 5 4GB
      ExarKunIvE S 2 Replies Last reply Reply Quote 0
      • ExarKunIvE
        ExarKunIv @retropieuser555
        @retropieuser555 why is xinit needed. It's a retroarch core. They don't need xinit to work
        • retropieuser555R
          retropieuser555 @ExarKunIv
          @ExarKunIv melondsds does, it has a strange geometry setting that doesn't play nice with runcommand, but the xinit setting allows it to launch fine
          Pi 5 4GB
          • ExarKunIvE
            @retropieuser555 I see.
            Then it must be on the pi5 then. Others have used it on the pi4 and have not reported anything.
            • retropieuser555R
              @ExarKunIv to clarify this isn't lr-melonds but lr-melondsds
              https://github.com/JesseTG/melonds-ds
              It's a fork that supports real microphones & a larger number of layout changes (specifically rotated screens for the book style DS games like Hotel Dusk)
              Pi 5 4GB
                sleve_mcdichael @retropieuser555
                (see next)
                  sleve_mcdichael @sleve_mcdichael
                  Oh, I see. You're trying to do (re: helpers.sh:function addEmulator):
                  ## For libretro emulators, cmd needs to only contain the path to the libretro library.
                  See the code which accomplishes this:
                      # automatically add parameters for libretro modules
                      if [[ "$id" == lr-* && "$cmd" =~ ^"$md_inst"[^[:space:]]*\.so ]]; then
                          cmd="$emudir/retroarch/bin/retroarch -L $cmd --config $md_conf_root/$system/retroarch.cfg %ROM%"
                      fi
                  ...in the expression ^"$md_inst"[^[:space:]]*\.so, I believe the first "^" character matches the start of the string. So when you add another $launch_prefix variable before the $md_inst, it fails to match. I think in this case, you should spell out the whole $cmd explicitly, something like:
                  addEmulator 0 "$md_id" "nds" "$launch_prefix$emudir/retroarch/bin/retroarch -L $md_inst/melondsds_libretro.so --config $md_conf_root/$system/retroarch.cfg %ROM%"
                  retropieuser555R 1 Reply Last reply Reply Quote 1
                  • ExarKunIvE
                    @retropieuser555 Oh
                    • LolonoisL
                      Lolonois
                      This post is deleted!
                      • retropieuser555R
                        retropieuser555 @sleve_mcdichael
                        @sleve_mcdichael Thanks for your help with this, you're a star. Oddly $system doesn't want to play ball and reports back empty, so I just changed that to nds directly and it works fine. Have added a PR into RetroPie Extras if anyone is curious to see the end result.
                        Oh also the core has networking support and works fine playing on wiimmf if anyone fancies a game of Mario Kart
                        Pi 5 4GB
