    retropie with raspberry pi5 + vga666 for crt tv
    setup
    5 Posts 3 Posters 684 Views
      kaneda
      Hi I have a raspberry pi5 with vga666, I installed retropie through this guide
      https://retropie.org.uk/docs/Manual-Installation/
      I want to use it on a pal crt tv
      i added this to config.txt
      dtoverlay=vc4-kms-dpi-generic
      dtparam=clock-frequency=13500000
      dtparam=hactive=640,hfp=52,hsync=64,hbp=108
      dtparam=vactive=240,vfp=26,vsync=3,vbp=43
      dtparam=hsync-invert,vsync-invert
      (i asked for help on raspberrypi forum)
      i can use Pi OS
      but if i launch retropie i get a black screen
      can you help me
        RetroPie support for the Pi5 is still pending, so some things might not work.
        There's no 'retropie' application, what exactly are you launching ? Are you using the RaspiOS Lite and starting EmulationStation from the command line ?
          kaneda @mitu
          @mitu said in retropie with raspberry pi5 + vga666 for crt tv:
          yes i launch EmulationStation
            DeMoN3
            Hi guys,
            I'm not sure that writing on this "old" post is correct, but my situation is similiar (Pi5 + VGA666 + CRT) and the config.txt too (I report my all config.txt at the end).
            I installed Retropie starting from RaspiOS Lite, and put emulationstation on the autostart, so when I switch on my Pi5 it starts automatically...and it works, I can see it and I can launch games. All works. Terminal, games and retropie applications views very well definited.
            But I've a problem: ES' interface (the system menu, the one that appears when you press start) is blurry and quite unreadable. I tried to change theme, now I'm using pixel-tft, but it didn't got better.
            I tried a lot of different config.txt configuration ("thanks" to chatgpt), but all of them caused the images to flicker, not only in ES but in terminal too. I also tried to use 480p and 480i or to specify in es_settings.xml to use a different (480x640, 800x800,1024x768) resolution...no results.
            Probably would be sufficient to magnify system font or to change colors (light gray against white isn't very contrastated), but I cannot find a file for doing this. I tried modifying the .xml of the theme (pixel-tft), but I didn't reach any result.
            It's really a shame, because the system works well, but this first impact gives a bad impression.
            How can i get a well readable ES interface?
            # Impostazioni di base
            dtparam=audio=on
            arm_64bit=1
            disable_fw_kms_setup=1
            arm_boost=1
            # Parametri per l'output VGA666 (DPI)
            enable_dpi_lcd=1
            display_default_lcd=1
            dpi_group=2
            dpi_mode=87
            dpi_output_format=6 # RGB666 senza sincronizzazione invertita
            hdmi_cvt=320 240 60 6 0 0 0
            # Impostazioni HDMI
            hdmi_force_hotplug=0
            hdmi_safe=1
              mitu Global Moderator @DeMoN3
              @DeMoN3 You should have opened a separate topic. While your setup may be similar to the original poster's setup, it's not the same problem. To answer to your question - you need to increase the resolution to get a better picture, the 240p you have won't work very well with ES.
