Wolfenstein 3D and Spear of Destiny no longer working with WOLF4SDL
@tvferret said in Wolfenstein 3D and Spear of Destiny no longer working with WOLF4SDL:
The instructions on RetroPie docs site are wrong
It seem that For Spear of Destiny they're incomplete and they're only referring to the Steam version. I'll add the info about GOG, I though the renaming was already mentioned in the docs since the GOG kit contains each episode in separate folders and they files are always named
.sod
. Thanks for testing. -
OK, I sorted it out. (...) One must copy/rename all 9 files (not just 3 as instructed) to sd1, sd2 and sd3.
Yes I am seeing this now too. Can confirm this is new behavior introduced between
f31f41a
anddc8b250
. New version requiresall 9 files(all 8, you don't needconfig.*
I think) share the same extension, eithersd1 sd2 sd3
(or.sod
).I didn't see this before because I didn't have eps 2 and 3 installed, and I'm using already the
sod
version filenames of ep1 for intercompatibility with ecwolf. -
Hi everyone. I have gone back and tried removing wolf4sdl and installing from source, but I also had the same issue @sleve_mcdichael experienced. I even tried changing the resolution to fit my screen (1920x1080 @ 50 Hz 16:9), but it just crashed and led back to the Ports menu. I am planning on downloading ecwolf, but in order for me to do that, it seems like I need to update my script (since version 4.8.9 or higher is needed for RetroPie-Extra). There's one problem however: I now see the "Update failed: fatal: Not possible to fast-forward. aborting." message appear on the screen. Is there any way to fix this? Once I get that done, I think I'll go to RetroPie-Extra to download ecwolf, rename the required files to what they were originally, and attempt to launch all the episodes one at a time. Thanks for all of your suggestions.
@Striderx99 said in Wolfenstein 3D and Spear of Destiny no longer working with WOLF4SDL:
This looks like you modified some of RetroPie's setup files or your repository is not RetroPie's. How did you install RetroPie ? What's the output of the following commands:
cd $HOME/RetroPie-Setup git remote -v git log -3 --pretty=oneline
I obtained the image from https://retropie.org.uk/download/ for my 4B+. Here are the results from the commands you listed above:
pi@retropie:~ $ cd $HOME/RetroPie-Setup
pi@retropie:~/RetroPie-Setup $ git remote -v
origin https://github.com/retropie/RetroPie-Setup.git (fetch)
origin https://github.com/retropie/RetroPie-Setup.git (push)
pi@retropie:~/RetroPie-Setup $ git log -3 --pretty=oneline
6598a90ab58da4b8917a58c2d33cc726f0ed10d5 (HEAD -> master) fixed lr-mess build
4142b443f0d2da902fc1ce17dc20d5ede5e98eb3 added my own fork of RetroCRT-240p theme
116265e5b675688c0410eae332e18a982bac17b6 Merge remote-tracking branch 'upstream/master'
pi@retropie:~/RetroPie-Setup $ -
@Striderx99 Are you using the https://github.com/valerino/retropie-setup fork in your setup ? Run the update and then provide the entire log from
$HOME/RetroPie-Setup/logs
@mitu I did use Valerino's fork at some point. I attempted to correct where the url was supposed to point to, but I probably made a mistake in that entry. How would I update RetroPie-Setup from here? Would I go to /home/pi/RetroPie-Setup/logs and check the most recent .log entry to post whatever message is listed on there afterwards? Thank you.
@Striderx99 Pleas provide the log info - as requested. Run the update as usual, get the error, then find the log file and unpack it. Copy the contents and post them on pastebin.com.
Btw, you should have mentioned you've been using a 3rd party repository when reporting the update error.
