    Problem with no sound in psx emulator
    psxsound issueraspberry pi 3bretropie 4.8
    3 Posts 2 Posters 398 Views
      Strongground
      productPi Model or other hardware: 3 B V.1.2
      Power Supply used: Official one, that came with the Pi
      RetroPie Version Used: 4.8
      Built From: I used the "Raspberry Pi Imager" tool to load it onto a SD card
      USB Devices connected: Generic USB controller
      Controller used: see above
      Error messages received: see message
      Guide used: I used the installation guide on this page.
      File: Every PSX ROM I tried so far (about ~100)
      Emulator: PSX
      How to replicate the problem:
      1. Start Retropie, custom intro video will play (with sound).
      2. Main menu shows, I can configure, go into menus, I hear menu sounds.
      3. Start any PSX game. It will play fine, (albeit some with graphical glitches like triangles only rendering from certain perspectives etc. but those are game/emulator specific problems), I can use "save game state" feature, everything works. Except sound. No sound from game videos, no CD-sound, no sound whatsoever.
      Notes: I used the 3.5 mm jack on the Pi. I don't have a monitor with speakers so I can't test HDMI audio - then again, the sound works fine for the intro video and Retropie menu.
      No error messages have been observed. I did look into a runcommand.log at one point but I am not sure what to look for - I think there where no audio related errors.
        Is the sound working in other systems and it's just the PS1 system doesn't have audio ? Did you use the 'save settings' menu in RetroArch at some point while playing a PS1 game ?
          Strongground @mitu
          @mitu Thanks for your help. In fact the game sound is working when using HDMI. I was originally not going to, so this would've been a huge problem. But since I am now using HDMI, everything is fine.
