    System Theme Switching
    themes
    2 Posts 2 Posters 294 Views
      rajbhalsod
      Hello, I've been setting up my raspberry pi/retropie again and having a lot of fun with it. Is it possible to switch between system themes? For example, I'm using the Carbon theme but if I was to then select SNES Classic from the menu, I would like it to switch to the SNES classic theme to resemble the real thing, if that makes sense?
      • mituM mitu moved this topic from Projects and Themes on
        You can switch the theme from EmiulationStation menus, if that's what you want - closing/backing out from the menu will apply the newly chosen theme to EmulationStation automatically.
