    SNES and PS not exiting with escape key
    snesno exitescape
    2 Posts 2 Posters 233 Views
    • hhcaseyH
      hhcasey
      I'm building a laptop controller with a raspberry inside for a friend.
      I got all of the arcade games working in Carbon with videos (thanks for the help).
      My curiosity now is that SNES, N64 and PS games will not let me exit.
      My Ultimarc is set to keyboard and I have a dedicated escape key to exit.
      These cores will not let me enter retroarch with the regular F1 key.
      I am working with a modified retroarch.cfg file I setup to remove conflicts between games and systems to work better with the keyboard.
      Specifically, I'm trying to stay with MAME key standards and remove anything that I don't want or need (fast forward, netplay, players 3-16, etc.)
      Any thoughts on what I've left out or overlooked.
      Pi Model or other hardware:3B+
      Power Supply used: Canakit 5v 2.5a
      RetroPie Version Used: v4.8.9 on Buster and Retroarch 1.19.1
      Built From: RetroPie website
      USB Devices connected: Ultimarc mini
      Controller used: Ultimarc mini - 8 game buttons, spinner, trackball, joystick, 4 admin buttons with ipac hot key (select, start, pause, enter, exit)
      Error messages received: na
      Verbose log (if relevant): na
      Guide used: na
      File: na
      Emulator: lr-mupen64plus, lr-pcsx-rearmed, lr-snes9x2010
      Attachment of config files: see below for all config
      ** Updated 01/15/2025
      ** Manually setup player 1 inputs
      ** Manually setup player 2 inputs
      ** Manually setup arcade buttons
      ** Manually nul for unwanted functions
      ** Deleted netplay references
      ** Delete references to gamepads
      ** 16 players... honestly.
      cache_directory = "/tmp/retroarch"
      core_options_path = "/opt/retropie/configs/all/retroarch-core-options.cfg"
      system_directory = "~/RetroPie/BIOS"
      config_save_on_exit = "true"
      video_threaded = "true"
      video_smooth = "true"
      video_aspect_ratio_auto = "true"
      video_font_size = "24.0"
      video_message_bgcolor_enable = "false"
      video_message_bgcolor_red = "0"
      video_message_bgcolor_green = "0"
      video_message_bgcolor_blue = "0"
      video_message_bgcolor_opacity = "1.0"
      input_joypad_driver = "udev"
      input_autodetect_enable = "true"
      menu_swap_ok_cancel_buttons = "false"
      ** Player buttons ************************************************
      input_player1_start = "num5"
      input_player1_select = "num1"
      input_player1_left = "left"
      input_player1_right = "right"
      input_player1_up = "up"
      input_player1_down = "down"
      input_player1_a = "ctrl"
      input_player1_b = "alt"
      input_player1_x = "space"
      input_player1_y = "shift"
      input_player1_l = "z"
      input_player1_r = "x"
      input_player1_l2 = "c"
      input_player1_r2 = "v"
      input_player2_start = "num6"
      input_player2_select = "num2"
      input_player2_left = "d"
      input_player2_right = "g"
      input_player2_up = "r"
      input_player2_down = "f"
      input_player2_a = "a"
      input_player2_b = "s"
      input_player2_y = "w"
      input_player2_x = "q"
      input_player2_l = "i"
      input_player2_r = "k"
      input_player2_l2 = "j"
      input_player2_r2 = "l"
      ** Special Keys ************************************************
      input_menu_toggle = "f1"
      input_save_state = "f2"
      input_load_state = "f3"
      input_state_slot_increase = "f6"
      input_state_slot_decrease = "f7"
      ** ipac does not need a key
      ** enter = "enter" does this need to exist?
      ** mame menu is tab
      input_exit_emulator = "esc"
      input_reset = "backspace"
      input_pause_toggle = "p"
      input_audio_mute = "f9"
      input_volume_up = "plus"
      input_volume_down = "subtract"
      all_users_control_menu = "true"
      menu_driver = "rgui"
      menu_show_online_updater = "true"
      menu_show_core_updater = "true"
      menu_unified_controls = "true"
      video_gpu_screenshot = "true"
      input_enable_hotkey = "i"
      auto_remaps_enable = "true"
      xmb_show_add = "false"
      xmb_show_history = "false"
      xmb_show_images = "false"
      xmb_show_music = "false"
      xmb_shadows_enable = "false"
      core_updater_buildbot_url = "http://buildbot.libretro.com/nightly/linux/armhf/latest/"
      core_updater_buildbot_assets_url = "http://buildbot.libretro.com/assets/"
      libretro_directory = "~/.config/retroarch/cores"
      libretro_info_path = "~/.config/retroarch/cores"
      content_database_path = "~/.config/retroarch/database/rdb"
      cheat_database_path = "~/.config/retroarch/cheats"
      content_history_path = "/opt/retropie/configs/all/content_history.lpl"
      content_favorites_path = "/opt/retropie/configs/all/content_favorites.lpl"
      content_music_history_path = "/opt/retropie/configs/all/content_music_history.lpl"
      content_video_history_path = "/opt/retropie/configs/all/content_video_history.lpl"
      content_image_history_path = "/opt/retropie/configs/all/content_image_history.lpl"
      cursor_directory = "~/.config/retroarch/database/cursors"
      screenshot_directory = "~/.config/retroarch/screenshots"
      input_remapping_directory = "~/.config/retroarch/config/remaps"
      video_shader_dir = "~/.config/retroarch/shaders"
      video_filter_dir = "default"
      core_assets_directory = "~/.config/retroarch/downloads"
      assets_directory = "~/.config/retroarch/assets"
      dynamic_wallpapers_directory = "default"
      thumbnails_directory = "~/.config/retroarch/thumbnails"
      playlist_directory = "~/.config/retroarch/playlists"
      joypad_autoconfig_dir = "~/.config/retroarch/autoconfig"
      audio_filter_dir = "default"
      savefile_directory = "default"
      savestate_directory = "default"
      rgui_browser_directory = "default"
      rgui_config_directory = "~/.config/retroarch/config"
      overlay_directory = "~/.config/retroarch/overlay"
      video_driver = "gl"
      record_driver = "ffmpeg"
      camera_driver = "null"
      wifi_driver = "null"
      location_driver = "null"
      audio_driver = "alsathread"
      audio_resampler = "sinc"
      input_driver = "udev"
      led_driver = "null"
      netplay_mitm_server = "nyc"
      video_aspect_ratio = "-1.000000"
      video_scale = "3.000000"
      video_refresh_rate = "59.940060"
      audio_rate_control_delta = "0.005000"
      audio_max_timing_skew = "0.050000"
      audio_volume = "0.000000"
      audio_mixer_volume = "0.000000"
      input_overlay_opacity = "0.700000"
      input_overlay_scale = "1.000000"
      menu_wallpaper_opacity = "0.300000"
      menu_framebuffer_opacity = "0.900000"
      menu_footer_opacity = "1.000000"
      menu_header_opacity = "1.000000"
      video_message_pos_x = "0.050000"
      video_message_pos_y = "0.050000"
      fastforward_ratio = "0.000000"
      slowmotion_ratio = "3.000000"
      input_axis_threshold = "0.500000"
      video_msg_bgcolor_opacity = "1.000000"
      state_slot = "0"
      netplay_check_frames = "600"
      input_bind_timeout = "5"
      input_turbo_period = "6"
      input_duty_cycle = "3"
      input_max_users = "2"
      input_menu_toggle_gamepad_combo = "0"
      audio_latency = "64"
      audio_resampler_quality = "2"
      audio_block_frames = "0"
      autosave_interval = "0"
      libretro_log_level = "1"
      keyboard_gamepad_mapping_type = "1"
      input_poll_type_behavior = "2"
      video_monitor_index = "0"
      video_fullscreen_x = "0"
      video_fullscreen_y = "0"
      video_window_x = "0"
      video_window_y = "0"
      video_window_opacity = "100"
      network_cmd_port = "55355"
      network_remote_base_port = "55400"
      keymapper_port = "0"
      dpi_override_value = "200"
      menu_thumbnails = "3"
      xmb_alpha_factor = "75"
      xmb_scale_factor = "100"
      xmb_theme = "0"
      xmb_menu_color_theme = "4"
      menu_font_color_red = "255"
      menu_font_color_green = "255"
      menu_font_color_blue = "255"
      materialui_menu_color_theme = "0"
      menu_shader_pipeline = "1"
      audio_out_rate = "48000"
      custom_viewport_width = "1600"
      custom_viewport_height = "1200"
      custom_viewport_x = "160"
      custom_viewport_y = "0"
      content_history_size = "100"
      video_hard_sync_frames = "0"
      video_frame_delay = "0"
      video_max_swapchain_images = "3"
      video_swap_interval = "1"
      video_rotation = "0"
      aspect_ratio_index = "21"
      user_language = "0"
      bundle_assets_extract_version_current = "0"
      bundle_assets_extract_last_version = "0"
      input_overlay_show_physical_inputs_port = "0"
      video_msg_bgcolor_red = "0"
      video_msg_bgcolor_green = "0"
      video_msg_bgcolor_blue = "0"
      ** deleted gamepads
      automatically_add_content_to_playlist = "false"
      ui_companion_start_on_boot = "true"
      ui_companion_enable = "false"
      video_gpu_record = "false"
      input_remap_binds_enable = "true"
      ** deleted netplay
      input_descriptor_label_show = "true"
      input_descriptor_hide_unbound = "false"
      load_dummy_on_core_shutdown = "true"
      check_firmware_before_loading = "false"
      builtin_mediaplayer_enable = "true"
      builtin_imageviewer_enable = "true"
      fps_show = "true"
      framecount_show = "true"
      ui_menubar_enable = "true"
      suspend_screensaver_enable = "true"
      audio_sync = "true"
      video_shader_enable = "false"
      video_shader_watch_files = "false"
      video_allow_rotate = "true"
      video_windowed_fullscreen = "true"
      video_crop_overscan = "true"
      video_scale_integer = "false"
      video_force_aspect = "true"
      video_shared_context = "false"
      auto_screenshot_filename = "true"
      video_force_srgb_disable = "false"
      video_fullscreen = "false"
      bundle_assets_extract_enable = "false"
      video_vsync = "true"
      video_hard_sync = "false"
      video_black_frame_insertion = "false"
      video_disable_composition = "false"
      pause_nonactive = "true"
      video_post_filter_record = "false"
      keyboard_gamepad_enable = "true"
      core_set_supports_no_game_enable = "true"
      audio_enable = "true"
      audio_mute_enable = "false"
      audio_mixer_mute_enable = "false"
      location_allow = "false"
      video_font_enable = "true"
      core_updater_auto_extract_archive = "true"
      camera_allow = "false"
      threaded_data_runloop_enable = "true"
      menu_throttle_framerate = "true"
      menu_linear_filter = "true"
      menu_horizontal_animation = "true"
      dpi_override_enable = "true"
      menu_pause_libretro = "true"
      menu_mouse_enable = "true"
      menu_pointer_enable = "false"
      menu_timedate_enable = "true"
      menu_battery_level_enable = "true"
      menu_core_enable = "true"
      menu_dynamic_wallpaper_enable = "false"
      quick_menu_show_take_screenshot = "true"
      quick_menu_show_save_load_state = "true"
      quick_menu_show_undo_save_load_state = "true"
      quick_menu_show_add_to_favorites = "true"
      quick_menu_show_options = "true"
      quick_menu_show_controls = "true"
      quick_menu_show_cheats = "true"
      quick_menu_show_shaders = "true"
      quick_menu_show_save_core_overrides = "true"
      quick_menu_show_save_game_overrides = "true"
      quick_menu_show_information = "true"
      kiosk_mode_enable = "false"
      content_show_settings = "true"
      content_show_favorites = "true"
      content_show_images = "true"
      content_show_music = "true"
      content_show_video = "true"
      content_show_netplay = "true"
      content_show_history = "true"
      content_show_add = "true"
      menu_show_load_core = "true"
      menu_show_load_content = "true"
      menu_show_configurations = "true"
      menu_show_help = "true"
      menu_show_quit_retroarch = "true"
      menu_show_reboot = "true"
      filter_by_current_core = "false"
      rgui_show_start_screen = "false"
      menu_navigation_wraparound_enable = "true"
      menu_navigation_browser_filter_supported_extensions_enable = "true"
      menu_show_advanced_settings = "false"
      materialui_icons_enable = "true"
      cheevos_enable = "false"
      cheevos_test_unofficial = "false"
      cheevos_hardcore_mode_enable = "false"
      cheevos_leaderboards_enable = "false"
      cheevos_badges_enable = "false"
      cheevos_verbose_enable = "false"
      input_overlay_enable = "true"
      input_overlay_enable_autopreferred = "true"
      input_overlay_show_physical_inputs = "false"
      input_overlay_hide_in_menu = "true"
      network_cmd_enable = "false"
      stdin_cmd_enable = "false"
      network_remote_enable = "false"
      keymapper_enable = "true"
      netplay_nat_traversal = "true"
      block_sram_overwrite = "false"
      savestate_auto_index = "false"
      savestate_auto_save = "false"
      savestate_auto_load = "false"
      savestate_thumbnail_enable = "false"
      history_list_enable = "true"
      playlist_entry_remove = "true"
      playlist_entry_rename = "true"
      game_specific_options = "true"
      auto_overrides_enable = "true"
      auto_shaders_enable = "true"
      sort_savefiles_enable = "false"
      sort_savestates_enable = "false"
      show_hidden_files = "false"
      audio_rate_control = "true"
      savestates_in_content_dir = "false"
      savefiles_in_content_dir = "false"
      systemfiles_in_content_dir = "false"
      screenshots_in_content_dir = "false"
      video_msg_bgcolor_enable = "false"
      video_window_show_decorations = "true"
      log_verbosity = "false"
      perfcnt_enable = "false"
      video_message_color = "ffff00"
      menu_entry_normal_color = "ffffffff"
      menu_entry_hover_color = "ff64ff64"
      menu_title_color = "ff64ff64"
      gamma_correction = "false"
      flicker_filter_enable = "false"
      soft_filter_enable = "false"
      soft_filter_index = "0"
      current_resolution_id = "0"
      flicker_filter_index = "0"
      xmb_font = ""
      content_show_settings_password = ""
      kiosk_mode_password = ""
      netplay_nickname = ""
      video_filter = ""
      audio_dsp_plugin = ""
      video_shader = ""
      menu_wallpaper = ""
      input_overlay = ""
      video_font_path = ""
      content_history_dir = ""
      resampler_directory = ""
      recording_output_directory = ""
      recording_config_directory = ""
      playlist_names = ""
      playlist_cores = ""
      audio_device = ""
      camera_device = ""
      cheevos_username = ""
      cheevos_password = ""
      video_context_driver = ""
      input_keyboard_layout = ""
      bundle_assets_src_path = ""
      bundle_assets_dst_path = ""
      bundle_assets_dst_path_subdir = ""
        Please large configs or logs on pastebin.com.
