    Citra-Nightly-2104 on Pi5 (screen issue) - Nintendo 3DS
    nintendo 3dsvulkanscript github
    16 Posts 3 Posters 5.5k Views
    • DTEAMD
      DTEAM
      Hello all,
      We can install a 3DS emulator on a Pi5 - Retropie that runs with Vulkan (WIP). See the following thread and here is the citra.sh file (draft). It works well, but very slowly in "Software" mode. The bad news is that it works fast with "Vulkan", but instead of having two different screens, we have a duplicate of the main screen in the second screen. The emulator works very well on other platforms like Microsoft Windows or other.
      Does anyone have an idea of ​​the source of the problem or how to fix this problem?
      For now, you must use citra-qt (UI mode), .3ds roms must be decrypted
      • mituM mitu moved this topic from Projects and Themes on
      • DTEAMD
        DTEAM @DTEAM
        Here's the log from /home/pi/.local/share/citra-emu/log
        https://pastebin.com/U9AsVEfv
        We can see many errors even if it loads and many warnings in the log
        New edition: here is the log without Vulkan but with the GraphicsAPI: "software" mode (which loads correctly):
        https://pastebin.com/Q2vNdFBF
        Differences beetween the 2 logs are only the addition of those lines for Graphic API Vulkan :
        [  61.456002] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:CollectTelemetryParameters:664: VK_DRIVER: V3DV Mesa 23.2.1
        [  61.456006] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:CollectTelemetryParameters:665: VK_DEVICE: V3D 7.1.7
        [  61.456008] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:CollectTelemetryParameters:666: VK_VERSION: 1.2.255
        [  61.456030] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:operator():430: Enabling extension: VK_KHR_swapchain
        [  61.456032] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:operator():430: Enabling extension: VK_KHR_image_format_list
        [  61.456033] Render.Vulkan <Warning> video_core/renderer_vulkan/vk_instance.cpp:operator():439: Extension VK_EXT_shader_stencil_export unavailable.
        [  61.456034] Render.Vulkan <Warning> video_core/renderer_vulkan/vk_instance.cpp:operator():439: Extension VK_EXT_external_memory_host unavailable.
        [  61.456036] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:operator():430: Enabling extension: VK_EXT_tooling_info
        [  61.456037] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:operator():430: Enabling extension: VK_KHR_timeline_semaphore
        [  61.456039] Render.Vulkan <Warning> video_core/renderer_vulkan/vk_instance.cpp:operator():439: Extension VK_KHR_portability_subset unavailable.
        [  61.456040] Render.Vulkan <Warning> video_core/renderer_vulkan/vk_instance.cpp:operator():439: Extension VK_EXT_extended_dynamic_state unavailable.
        [  61.456041] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:operator():430: Enabling extension: VK_EXT_custom_border_color
        [  61.456042] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:operator():430: Enabling extension: VK_EXT_index_type_uint8
        [  61.456043] Render.Vulkan <Warning> video_core/renderer_vulkan/vk_instance.cpp:operator():439: Extension VK_EXT_fragment_shader_interlock unavailable.
        [  61.456043] Render.Vulkan <Info> video_core/renderer_vulkan/vk_instance.cpp:operator():430: Enabling extension: VK_EXT_pipeline_creation_cache_control
        [  61.456045] Render.Vulkan <Warning> video_core/renderer_vulkan/vk_instance.cpp:operator():439: Extension VK_KHR_fragment_shader_barycentric unavailable.
        [  61.472567] Render.Vulkan <Warning> video_core/renderer_vulkan/vk_instance.cpp:CreateFormatTable:305: Format B8G8R8Unorm unsupported, falling back unconditionally to R8G8B8A8Unorm
        [  61.500407] Render.Vulkan <Info> video_core/renderer_vulkan/vk_stream_buffer.cpp:CreateBuffers:176: Creating Stream buffer with size 128 KiB with flags { DeviceLocal | HostVisible | HostCoherent }
        [  61.625900] Render.Vulkan <Info> video_core/renderer_vulkan/vk_stream_buffer.cpp:CreateBuffers:176: Creating Upload buffer with size 524288 KiB with flags { DeviceLocal | HostVisible | HostCoherent }
        [  61.979534] Render.Vulkan <Info> video_core/renderer_vulkan/vk_stream_buffer.cpp:CreateBuffers:176: Creating Download buffer with size 16384 KiB with flags { DeviceLocal | HostVisible | HostCoherent }
        [  62.011588] Render.Vulkan <Info> video_core/renderer_vulkan/vk_stream_buffer.cpp:CreateBuffers:176: Creating Stream buffer with size 65536 KiB with flags { DeviceLocal | HostVisible | HostCoherent }
        [  62.055379] Render.Vulkan <Info> video_core/renderer_vulkan/vk_stream_buffer.cpp:CreateBuffers:176: Creating Stream buffer with size 4096 KiB with flags { DeviceLocal | HostVisible | HostCoherent }
        [  62.057886] Render.Vulkan <Info> video_core/renderer_vulkan/vk_stream_buffer.cpp:CreateBuffers:176: Creating Stream buffer with size 2048 KiB with flags { DeviceLocal | HostVisible | HostCoherent }
        [  62.058809] Render.Vulkan <Info> video_core/renderer_vulkan/vk_stream_buffer.cpp:CreateBuffers:176: Creating Stream buffer with size 2048 KiB with flags { DeviceLocal | HostVisible | HostCoherent }
        and this
        [  62.232942] Render.Vulkan <Info> video_core/renderer_vulkan/vk_pipeline_cache.cpp:LoadDiskCache:165: Loading pipeline cache with size 57 KB
          gvx64 @DTEAM
          @DTEAM For what little it is worth, my honest opinion is that it is probably not worth it to try to get Citra working on the Pi using Vulkan unless we can find an experienced graphics developer to work on it. Vulkan support on Citra looks very preliminary - if it had a couple more years of development time before the plug got pulled on Citra development I think this might have not been the case. Vulkan is a very complex API to program for and even dolphin required 1000's of commits before its Vulkan backend matured enough to become usable. For example, if you watch the below video showing Citra running on the Pi5, specifically the portions where Sun/Moon is played you will see that the screen duplication issue is far from the only issue that Citra has running Vulkan. It looks like it also has major issues with rendering pretty much anything 3D:
          I actually built your version of Citra and ran Etrian Odyssey Untold The Millennium Girl and using an existing save file. Using Vulkan, it handled the menu system really well but the screen went black as soon as I entered a dungeon (where there is rendering of 3d polys). Please let me know if you have a different experience here.
          Honestly, I don't understand why Raspberry Pi OS still doesn't support GLES 3.2. Apparently the Pi's GPU is compliant, it's just that the drivers don't support it. In this case, I suspect that Citra's GLES 3.2 support is far more mature than Vulkan and Citra would likely be running quite well on the Pi using that API. Do you think that there is any chance that we can get the MESA folks to revisit GLES 3.2 compliance? It sounded like they were very close a few years ago on the Pi4 and then just stopped and moved over to Vulkan. I really believe that support for the GLES 3.2 API would be more valuable for emulation than Vulkan.
          retropieuser555R DTEAMD 2 Replies Last reply Reply Quote 1
          • retropieuser555R
            retropieuser555 @gvx64
            @gvx64 said in Citra-Nightly-2104 on Pi5 (screen issue) - Nintendo 3DS:
            Fwiw 3DS emulation is in a weird flux right now given there's multiple competing software that is all derivatives of Citra it appears.
            Give it a few years for an obvious front running to come forward, as a bunch of them right now do boot into arm64 (I'm using Panda3ds and found it's good for Fantasy Life, Pushmo and some others) but they're in very early stages of development
            Pi 5 4GB
            DTEAMD 1 Reply Last reply Reply Quote 2
            • DTEAMD
              DTEAM @retropieuser555
              @retropieuser555 @gvx64
              Thanks for your comments. With your work with Dolphin for the Pi, I was hoping you would respond to this thread. I'm happy to hear your thoughts. I'm currently chatting with one of the people who wants to restart the project. If you feel like commenting or helping out on this thread, you're more than welcome.
              https://github.com/Borked3DS/Borked3DS/issues/330
              He seems to be interested to help for Pi5
              For GLES 3.2 I saw Mesa and GLes in the same sentence here. Don't know if it can help
              https://www.glfw.org/docs/latest/compile.html
              https://discourse.glfw.org/t/glfw-and-mesa/176
              • DTEAMD
                DTEAM @gvx64
                Yes but I didn't play with the API setups. We don't have this problem with Vulkan on Microsoft Windows. I always compare the game performance on both systems and I agree with you, the development of this emulator on Linux/Mesa (Pi5) with Vulkan is not at the same level than the one on Microsoft Windows.
                I'm looking forward to seeing if someone with the skills will take this on with the Borked3DS project. It's one of the only new projects alive that continues where Citra left off.
                Thanks again for your comments!
                  gvx64 @DTEAM
                  @DTEAM I appreciate your kind words. The thing is that I am not an actual software dev like the people who create these emulators. I am just notoriously bad at giving up on things once I start which somewhat masks my lack of experience to a degree. That said, even on dolphin-rpi most of my work was rolling-back and rolling-forward the commits of actual devs, filling in a few blanks here and there and then just handling the debugging of the code.
                  On the topic of GL ES 3.2, I did some more reading and it sounds like Broadcom actually has internal drivers that are fully GL ES 3.2 conformant for the Raspberry Pi's GPU but they won't share it with Raspberry Pi Foundation. The Rapsberry Pi Devs have not been able to pass all of the necessary GLES 3.2 conformance tests using their own drivers and so I don't know if they are still actively pursuing it (source: https://forums.raspberrypi.com/viewtopic.php?t=260995#p1589780). I know that Raspberry Pi4's Secondary Memory Interface details eventually found its way into the hands of the general public (and that was Broadcom internal for a long time) and so who knows what might happen one day with those working GL ES 3.2 drivers. I believe that releasing these drivers (at least to the Pi engineers) would go along way to provide the missing piece to the puzzle of GL ES 3.2 support on the Pi. GL ES 3.2 which would deliver significant benefit to emulators on the Pi like Citra, dolphin, AetherSX2, and probably a lot of others so if somebody at Broadcom reads this, please do the right thing.
                  Anyways, I do not want to get anybody's hopes up as I am not experienced with graphics programming (which is why I am voiding Vulkan completely) and this may not work out all but I am investigating if it might be feasible to replace the GLES 3.2 API entry points in Citra that are not supported by the Pi with supported ones. It does seem that my Pi4 running the current MESA Bookworm drivers does support at least some GL ES 3.2 extensions and so it is possible that it may only require a reasonable amount of modification to the opengl renderer backend to get it to the point of functionality on the Pi. I can already get the build of citra you linked above to launch in via GL if I do the following:
                  Edit the file in the citra sourc-code before compiling:
                  ../src/citra/default.ini.h (line 107) change to:
                  use_gles = 1
                  and then, after building, launch Citra with the following command (you will need xinit after the env variables before the program path if you're are not in the desktop):
                  MESA_GLES_VERSION_OVERRIDE=3.2 MESA_GLSL_VERSION_OVERRIDE=320 /home/pi/citra/Build/bin/Release/citra-qt
                  Using this method, I am able to get good performance in the fmv and menu system of Etrian Odyssey Millennium Girl. No screen duplication and I can even edit the map screen. The game crashes when I enter a 3D dungeon because of a segfault that occurs from the fact that glMapBufferRange() function does not support gl_texture_buffer targets pre-GL ES 3.2, which is not surprising. I assume that any 3D rendering will generate a segfault at this point but it is more than I expected that 2D menus/maps and full-motion video cutscenes seem to work perfectly at least in this one game. Right now, I see more potential getting Citra on the Pi working using GLES than I do from Vulkan (especially in the context of me modifying this code with my limited abilities).
                  DTEAMD 2 Replies Last reply Reply Quote 0
                  • DTEAMD
                    DTEAM @gvx64
                    @gvx64
                    Thanks for your reply
                    Right now, I'm doing some testing (basically I create log files) for a new project that combines all previous projects. https://github.com/Borked3DS
                    -Currently, we managed to compile with a shell and load games with Vulkan with two screens. The guy (Rtiangha) fixed the bug mentioned above. To compile and have a better experience you also need MESA (faster) and CMake from the backport. We can run some games without problems like Mario Kart 7. Most games have a black screen issue or close after some menu selections.
                    Here are the two reported issues. One is closed and the other is active. Feel free to help us.
                    https://github.com/Borked3DS/Borked3DS/issues/356
                    Maybe another way to fix the bug, will be the installation of MESA 24.3/Vulkan1.3. Don't know if I need to install Debian 13 - Trixies (in develop.) to do that or go above the actual backport limitations. I have read Vulkan 1.3 is stable on a Pi5
                    • After that, in my mind, the hotkeys for gampepads will be the next big thing to fix, the rest will be fine tunings .
                    This is very interesting. thanks
                    • DTEAMD
                      DTEAM @gvx64
                      This post is deleted!
                        gvx64 @DTEAM
                        @DTEAM said in Citra-Nightly-2104 on Pi5 (screen issue) - Nintendo 3DS:
                        @gvx64
                        Yes, good point. In addition to that I would like to add functionality allowing an analog stick to control a stylus cursor similar to how it is done in MelonDS. That said, I need to figure out the video backend problem before I think too much about that.
                        Regardless, continue with your good work here. I actually like that we are taking different routes to find a solution to the rendering problems on the Pi, if one of us hits a dead-end then there is a fallback.
                        • DTEAMD
                          DTEAM @gvx64
                          @gvx64
                          I succeed to install MESA 25.0.0-1/Vulkan 1.4 (Debian 13 - trixie) with
                          deb http://ftp.de.debian.org/debian sid main
                          and
                          sudo apt install -t sid mesa-va-drivers
                          It's experimental, but will see. I'll do some test with Borked3DS and his official repo today
                          New editL : Unlike the "backport" option, the "sid" option creates slight bugs in Retropie. I don't recommend installing this version for now if you want your Retropie to be clean. They say that several bugs will be fixed in version 25.0.1. Do a backup first.
                          Retropie Bugs with what I did are for now :
                          • audio mixer
                          • line 181 system.sh
                          • line 375 system.sh
                          • line 963 package.sh
                          Also, I had to reinstall Dolphin and it works now. No impact on other emulators.
                          • DTEAMD
                            DTEAM @DTEAM
                            @gvx64
                            Borked3ds hit a dead end for now. I agree with you they need someboby with Vulkan skills
                            BTW. MESA 25.0.0 is unstable or hard to manage and it's more a problem than a solution for now. Also, I was not able to run and to compile/reinstall your dolphi-rpi with MESA 25.0.0. I'll go back with bookworm backport for now. I'll do another test in few months.
                            G 1 Reply Last reply Reply Quote 2
                              gvx64 @DTEAM
                              @DTEAM Thank you for the updates on this. I actually didn't know when I made my first post on this thread that Vulkan on Citra was working fine on Windows. The amount of work needed to get it working on the Pi may not be as substantial as I thought, especially with the screen duplication issue has been corrected on the Borked3DS fork as you say.
                              I don't know much about Vulkan but if you think it would be worthwhile I can try building the Borked3DS build and seeing if I can figure out what the problem might by hacking around the old fashioned way. I can probably only fix something simple, but if nothing else I can probably at least tell you and the dev you are working with where the code is getting hung up.
                              • DTEAMD
                                DTEAM @gvx64
                                Yes please. I'm running MESA 24.3/Vulkan 1.3 (Debian testing) and it's pretty stable on Pi and all the emulators work well including your dolphin-rpi version. I'm not an expert but I think the problem with Borked3DS is not only a Vulkan problem. I think it doesn't handheld something else. See the last comment in this thread.
                                  gvx64 @DTEAM
                                  @DTEAM Sorry for bumping this old thread, but I didn't want to keep posting on the old github issue thread.
                                  I just wanted to let you know that I have committed another update that fixes shader gen issues for games such as Poochy & Yoshi's Woolly World that was causing a crash at launch. These games are now fairly playable on an aggressively overclocked Pi4 specifically if you disable "New 3DS" mode. Doing this cuts the framerate in this game from 60fps down to 30fps and dramatically improves performance. I am also keeping Right Eye disabled since this is a 2D game. Another trick I found to boost performance ever so slightly was to turn game speed up over 100% (eg. 130%). It certainly will not boost the game up to that speed if the game is running slow but I did notice a slight increase in speed across the board.
                                  Also, I mentioned this on the git issue thread but I added support for GL_OES_texture_buffer in Borked3ds-rpi. This is a GLES 3.2 extension that the Pi does not completely support, but the code in Borked3ds-rpi does not depend on the problematic portions of this extension and so we can tap into this GLES 3.2 functionality on the Pi by using an environment variable override. to launch within Retropie with GL_OES_texture_buffer support enabled, edit the contents of /etc/emulationstation/es_systems.cfg so that the 3DS entry appears as follows. This will theoretically give better performance than the fall-back code path that uses 2D texture LUTs and it should be more accelerated in games that have fog/lighting effects (that said, I am not noticing much of an improvement on my Pi4, maybe because it's GPU is too weak for it to matter).
                                    <system>
                                      <name>3ds</name>
                                      <fullname>3ds</fullname>
                                      <path>/home/pi/RetroPie/roms/3ds</path>
                                      <extension>.3ds .cci .zip  .3DS .CCI .ZIP </extension>
                                      <command>env MESA_EXTENSION_OVERRIDE="GL_OES_texture_buffer" /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ 3ds %ROM%</command>
                                      <platform>3ds</platform>
                                      <theme>3ds</theme>
                                    </system>
                                  For those that are new to this conversation, instructions on building Borked3ds-rpi are on the github page (@DTEAM may also have a build script): https://github.com/gvx64/Borked3DS-rpi/tree/master
                                  Note that you need to set the graphics API in the settings to OpenGL and then click "Use GLES extensions". The Vulkan extension sort of works but it is not great and it has the same rendering issues that you see in all of the recent Citra forks (GLES 3.1 support is what sets this fork apart). Also, note that I am not the original author of this work, Reg Tiangha did the vast majority of the work on this build of Borked3ds that is meant to run on the Pi and deserves full credit. I forked it after he dropped the project.
                                  • DTEAMD
                                    DTEAM @gvx64
                                    @gvx64
                                    Nice work! Do you think we should create a "Borked 3DS" thread on Retropie ?
